![]() | Home > Maintenance & Mods (L405) > Deployable Steps Trim |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
The trim on my car is short and the steps come with extra length to protect the steps and look neater, I had front mud flaps fitted and they have to be changed to fit the extra length cover. |
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 ![]() ![]() ![]() |
Hi ya,
Normal Autobiography. I take it you tried Duckworths. |
Hi ya,
Did you get the extra protection bits of plastic, and when you ordered did you give them all the specs of your car? |
I have got the bits all separate. On TOPIX, its the kit listed for my car and the plastic trim doesnt match the car.
I have sent you a PM |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
SV man, they do NOT make the part you're looking for, unfortunately... That panel is only made for the standard body type NOT the SVO kit sir... |
Hi ya,
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 911 ![]() ![]() ![]() |
I think you’ll need the standard panel with the cut out, as the step when retracted sits into this recess, which your SV panel may not have? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
thinking outside the box here, what about cutting a little bit off the step where it would recess into the trim... ... - .- -.
From what I spotted online, with the SV trim the step sits almost on top of it. The standard trim just adds a bit to blend it in more.
There is no need to cut anything as they can move on the fixings forward /backwards.
Another option is use some of the bits that are for the RRS.
