Home > General > Jet washing advice
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Jet washing advice
Hi.
I have a jet washer which I use around the garden etc. I was wondering how suitable this is for cleaning my FF. I wouldn't normally have much concern but there are so many electrical bits in the car I have some worries about water being forced into anywhere it shouldn't be. I am particularly thinking about cleaning under wheel arches and around wheels and brakes etc, but I am mindful of doing too much as I knackered the alternator on my Discovery a few years ago when it appears some water shorted out some components after I cleaned the engine bay.
I am sure somebody will just say "use it on low power then" but then I may as well use a normal hose.
Any thoughts folks? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #70112 27th Jun 2011 12:30pm
I used a power wash on my FFRR wheel arches yesterday, not a problem Thumbs Up
Post #70113 27th Jun 2011 12:31pm
as you know a pressure washer will only take off surface dirt so you still need to either snow foam the car or wash it with car shampoo and then pressure wash the foam/shampoo off...
you are so right about the many electronics on the range and i for one only use my pressure washer on the wheels and underneath [like you suggested].
i use a waterless cleaning solution like the stuff you get on the shopping channels and it works well but there are times when water is preferable ..these times i wash with sponge and car shampoo and use the normal garden hosepipe to 'rinse' the car ...
Post #70114 27th Jun 2011 12:38pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i use a jet washer everytime no problems
Post #70118 27th Jun 2011 12:56pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Used a washer on all my cars never had an issue in 15 years Inc cars that have more sensors than a rangey. Only place to be very careful is under the hood !! Far to many gone...
Post #70126 27th Jun 2011 3:12pm
Always use a pressure washer - for initial pre-wash rinse & final rinse.
If there's an imperfection in the paintwork it will find it but that's no bad thing - mine lifted the laquer off the front bumper - so it wasre-sprayed FOC under warrnaty.
Post #70196 27th Jun 2011 7:02pm
RRG
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
I think you can relax and use your pressure washer - the FFRR is very well sealed against water ingress. If you remove some of the electrical connectors under the bonnet you will find they are triple sealed against water/dust. The only thing I would advise is extreme caution with the environmental box housing all the engine management etc.
One slightly amusing story: Having driven the Range to Nairobi it went into the local LR dealer for a through service - under my supervision. It was filthy as you can imagine and I asked for a thorough jet wash before we started work. I had only turned my back for two minutes to find the bonnet up and a Kenyan jet washing the entire engine bay for all it was worth. I cringed and wondered at the catastrophic problems this was going to cause... only to have no problems whatsoever.
RRG
Post #70215 27th Jun 2011 7:59pm
rrg, the nairobi trip sounds good ..any more info/pics..[best start new thread]
Post #70218 27th Jun 2011 8:09pm
RRG
Stan
go to the Africa section of this forum - it is the only post in that section - there you will find a very full write-up and links to my website / photos etc. Caution: you will need a big cup of coffee...
RRG
Post #70252 27th Jun 2011 10:11pm
Post #70263 28th Jun 2011 6:39am
