Home > Technical (L322) > 4.4TDV8 FBH - quick question!
JMC
On my 08 3.6 Vogue, the FBH would run when starting a cold engine if the ambient temp was under 5deg.
Question is, does the FBH work in exactly the same way on the 4.4 TDV8? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #646160 21st Oct 2022 10:11pm
mjdronfield
I believe so. Mine does the same.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #646161 21st Oct 2022 10:14pm
JMC
Chap on t'Internet is telling me it doesn't, and he's the admin on the 4.4 TDV8 FB page....... Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #646162 21st Oct 2022 10:21pm
mjdronfield
From the Workshop Manual….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #646163 21st Oct 2022 10:48pm
mjdronfield
Or the manual…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #646164 21st Oct 2022 10:59pm
JMC
Thanks MJ!
Can you confirm this is specifically the 4.4 TDV8 manual? I've been investigating on-line, but can't get into Topix The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #646165 21st Oct 2022 11:02pm
mjdronfield
Yes, it’s the 4.4 TDV8.
The Workshop Manual is in the Wiki, but you’ll have to download it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #646166 21st Oct 2022 11:12pm
JMC
Thanks again MJ!
Yes, I have the workshop manual downloaded, but aside from instructions on repairs and torques, I couldn't find an explanation of the system in it.
I suppose I could have gone out to the car to look at the manual, but it's dark, cold and wet out there tonight! Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #646167 21st Oct 2022 11:18pm
garyRR
I'm just working on a phone controlled switch with a temperature switch for the FBH, to replace the need for the remote and enable me to turn on the FBH from anywhere.
Seems like a nice little mod to do, especially if you don't already have a remote. 2015 Range Rover Autobiography 4.4 SDV8
Post #646169 21st Oct 2022 11:31pm
Must be true then, if he's admin on a FB page Whistle Whistle Whistle Laughing
Post #646175 22nd Oct 2022 12:23am
JMC
Rolling with laughter Rolling with laughter Rolling with laughter The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #646177 22nd Oct 2022 12:31am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
FBH as pre-heater (from fob or timed-climate):
.. to -20° will run and heat cabin (not engine)
-20° and lower will run and heat cabin and engine
FBH as auxiliary heater (cold engine start):
.. to +8° will not run
+8 and lower will run.
Post #646179 22nd Oct 2022 5:04am
kevinp
JMC, I don't know whether it's relevant that my car hasn't been started for a few weeks but the last couple of days when starting with a cold engine, the FBH has shrouded my street with a smoke cloud and the outside temperature was about 8-10 degrees.
I've never used the timed setting and don't have a remote fob.
Cheers Kev.
Post #646190 22nd Oct 2022 9:59am
jaguar3
Smoke mean late ignition. If not use long time its normal at first start. If its continue, burning chamber need to replace (evaporator fault, not serviceble).
Post #646193 22nd Oct 2022 10:48am
Rambles
In very cold conditions ……
There is a changeover valve which can isolate the engine coolant circuit from the heating coolant circuit for cabin heat.
And this happens at 15 degrees and below
BUT
In very cold conditions,
-20 degrees and below
The changeover valve is not energised and the blower is not activated. Heated coolant is circulated around the engine and heater cores to heat the engine and aid starting.
No blower means no cabin heat …..
Never experienced -20 and below in Uk so cannot talk from experience, but this is from the workshop manual.
Post #646200 22nd Oct 2022 1:14pm
