Home > Technical (L322) > 4.4TDV8 FBH - quick question! |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
On my 08 3.6 Vogue, the FBH would run when starting a cold engine if the ambient temp was under 5deg.
21st Oct 2022 9:11pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7781 |
I believe so. Mine does the same.
21st Oct 2022 9:14pm |
Chap on t'Internet is telling me it doesn't, and he's the admin on the 4.4 TDV8 FB page....... The older I get, the more I realise that people confuse wrinkles for wisdom |
21st Oct 2022 9:21pm |
From the Workshop Manual….
21st Oct 2022 9:48pm |
Or the manual…..
21st Oct 2022 9:59pm |
Thanks MJ!
21st Oct 2022 10:02pm |
Yes, it’s the 4.4 TDV8.
21st Oct 2022 10:12pm |
Thanks again MJ!
21st Oct 2022 10:18pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16269 |
Must be true then, if he's admin on a FB page |
21st Oct 2022 11:23pm |
21st Oct 2022 11:31pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
FBH as pre-heater (from fob or timed-climate):
22nd Oct 2022 4:04am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
JMC, I don't know whether it's relevant that my car hasn't been started for a few weeks but the last couple of days when starting with a cold engine, the FBH has shrouded my street with a smoke cloud and the outside temperature was about 8-10 degrees.
22nd Oct 2022 8:59am |
Smoke mean late ignition. If not use long time its normal at first start. If its continue, burning chamber need to replace (evaporator fault, not serviceble). |
22nd Oct 2022 9:48am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 797 |
In very cold conditions ……
22nd Oct 2022 12:14pm |
