Home > Technical (L322) > Range Rover TDV8 4.4 2011 Won’t Start
Rangey1
United Kingdom 2003 Range Rover HSE 4.4 V8 Monte Carlo Blue
Thanks for all the pointers.
I’ve checked the battery again and will try and attach photos.
Will try checking everything else now.
Post #645164 9th Oct 2022 10:12am
Rambles
If voltage is 12.6v with the charger on and connected, it is not charging…..
Normal charging for an AGM will be between 14.2 and 15 depending on state of battery and temperature
Float / maintenance charge is something like 13.7
Post #645176 9th Oct 2022 11:45am
Rangey1
Will running a small wire from the small wire on the starter motor damage the ECU, if I connect it back to the battery to try and start it?
Post #645180 9th Oct 2022 12:28pm
Rangey1
dhallworth wrote:
If you keep the window down or the door open, can you hear a click when you press the button?
Starter motors on the 4.4 TDV8 are quite common points of failure.
David.
Ive taken the starter motor off and checked it on the vice and all good, put it back in the car and nothing.
Post #645190 9th Oct 2022 2:59pm
Rangey1
Would the alternator stop the car from starting?
Post #645191 9th Oct 2022 3:01pm
Chrali
Whilst you may have a faulty starter, does a new battery need to be coded to the car? If it needs to be and isn't I'd imagine it wont change correctly. Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #645211 9th Oct 2022 8:11pm
Rangey1
I’ve told it the battery’s been changed but it was doing this before the battery was changed.
Post #645212 9th Oct 2022 8:26pm
GraemeS
Can you get decent battery voltage with the charger connected but with a battery lead disconnected?
Post #645214 9th Oct 2022 8:48pm
garyRR
David.
Does the ignition come on, just the engine not crank?
How did you test the starter motor? Just to make sure it moved freely or with a spare battery to confirm it engages and runs?
If the starter motor is functioning and the ignition turns on, then I'd definitely be looking at the circuit between the starter motor and the battery.
Can you get a multimeter clipped to the end of the connector on the starter to see if it's getting voltage when you press the start button? If no voltage then, inspect/change the starter relay (relay 6 in the engine junction box), to see if that is working when the starter button is pressed? There's the relay and 2 fuses to check.
The above steps should help find where in the line between pressing the start button and the engine starting the issue is - ECU end, battery, relay or starter motor end, as exemplified by the wiring diagram. 2015 Range Rover Autobiography 4.4 SDV8
Post #645218 9th Oct 2022 10:10pm
dhallworth
How did you test your starter?
When the starter failed on ours, it would still spin when we applied voltage to the terminals directly but the bendix wouldn't engage when triggering it normally.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #645250 10th Oct 2022 9:27am
