Home > Technical (L322) > Range Rover TDV8 4.4 2011 Won’t Start |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 789 |
If voltage is 12.6v with the charger on and connected, it is not charging…..
9th Oct 2022 12:45pm |
Rangey1 Member Since: 31 Jul 2021 Location: Wales Posts: 12 |
Will running a small wire from the small wire on the starter motor damage the ECU, if I connect it back to the battery to try and start it? |
9th Oct 2022 1:28pm |
Ive taken the starter motor off and checked it on the vice and all good, put it back in the car and nothing. |
9th Oct 2022 3:59pm |
Would the alternator stop the car from starting? |
9th Oct 2022 4:01pm |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
Whilst you may have a faulty starter, does a new battery need to be coded to the car? If it needs to be and isn't I'd imagine it wont change correctly. Encourage alternative fuels, use all the petrol!
9th Oct 2022 9:11pm |
I’ve told it the battery’s been changed but it was doing this before the battery was changed. |
9th Oct 2022 9:26pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2389 |
Can you get decent battery voltage with the charger connected but with a battery lead disconnected? |
9th Oct 2022 9:48pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1452 |
Does the ignition come on, just the engine not crank? How did you test the starter motor? Just to make sure it moved freely or with a spare battery to confirm it engages and runs? If the starter motor is functioning and the ignition turns on, then I'd definitely be looking at the circuit between the starter motor and the battery. Can you get a multimeter clipped to the end of the connector on the starter to see if it's getting voltage when you press the start button? If no voltage then, inspect/change the starter relay (relay 6 in the engine junction box), to see if that is working when the starter button is pressed? There's the relay and 2 fuses to check. The above steps should help find where in the line between pressing the start button and the engine starting the issue is - ECU end, battery, relay or starter motor end, as exemplified by the wiring diagram. 2015 Range Rover Autobiography 4.4 SDV8 |
9th Oct 2022 11:10pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3030 |
How did you test your starter?
10th Oct 2022 10:27am |
