Home > Maintenance & Mods (L405) > Gearbox oil change
supershuttle
Gearbox oil change
As I've done over 100k miles I thought I would change the gearbox oil. However, I have been quoted over 500 quid which actually is more expensive than a service, is the oil that expensive or is it a BIG job? Geoff
Post #644788 4th Oct 2022 7:02pm
fisha
It depends ... Laughing
There are varying degrees of gear box oil change, but know first that if you simply unbolt the drain plug and let the fluid out ... you'll only letting about half of the total contents of the box out. the other half remains in the torque converter and pipeworks inside the box.
That means you can change the fluid a number of ways:
- drain half then refill - 50% of fluid changed. Repeat the process again = 75% changed , then 87.5% etc etc. This is an easy method, can be done on the driveway ... but beyond 2 changes, you begin using more fluid that what the box could hold, so a little wasteful potentially.
- a full flush / megaflush - you tap into the pipes which run from the box to the radiators at the front. As the geadbox pump pushes fluid to the radiator cooler, you re-direct that into a drain, then pump in new fluid at the same rate into the rest of the pipe circuit. This way, you can change the whole lot in 1 go. Whilst potentially using less fluid that above, it a more involved process normally needing dedicated equipment.
- replace the filter + fluid. Drain the box, take the sump off, replace the filter, put back together and refill ( by either of the 2 above methods ). additional costs for filter, and its replacement.
So, various ways, various costs. So hard to say whether your price is good or bad, depending on the work done. V8 or else ...
Post #644791 4th Oct 2022 8:01pm
knwatkins
Re: Gearbox oil change
This is what I did. I used Mannol AG60 and paid £72 for 20 litres of it back in 2020. See my post at the bottom of the first page of my thread here: https://www.fullfatrr.com/forum/topic57338.html
Dead easy to do on the driveway and gearbox still silky smooth 2 years on and 20k miles later Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #644793 4th Oct 2022 9:14pm
Dolphinboy
Geoff, here's the bill from mine, although I did get it done at the same time as the oil cooler. I was charged 1 hr labour for the gearboxes. On its own could have been more I guess? total cost for gearboxes/transfer box on their own was c. £300
Oil was £154 (7 litres at£22/Ltr). transfer box £30 - all plus Vat obvs!!
Here's my bill:
Post #644806 4th Oct 2022 11:27pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Or, you could give Bodsy a call. I had Ian change my gbox oil and both diffs when I purchased the car. His number is 07770 638023 and he is very reasonably priced.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #644811 5th Oct 2022 6:52am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I just contacted RCV for this and they advised against changing the oil unless the gearbox has issues. I am undecided now....
https://www.rcv.co.uk/
Post #687440 7th Mar 2024 10:42am
knwatkins
That really isn't good advice.
Go by what the manufacturer says which is to service it ever 50k to 70k. Kev
Post #687442 7th Mar 2024 10:48am
CS
When booking my 6y service (61,000 miles) I asked about gearbox oil change and was told that LR's schedule was 100,000 miles. I might aim to get it done at the next service, so maybe 75,000 miles. Only Range Rovers since 1988
Post #687444 7th Mar 2024 11:24am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Proper old-school view that is. In the US, where they've bought 80%+ of their vehicles with autoboxes for many decades, generally automatic boxes are understood to require regular fluid/filter changes, and there are numerous places where you can have that done often 'while you wait'.
No fluid has an infinite life, and gearbox internals wear, depositing debris in the oil. The filter cleans that up, but a filter doesn't have an infinite life (although, of course, technically its ability to 'filter', although not maintain flow rate, is at its very best at the exact moment preceding it becoming 100% clogged).
Automatic transmission manufacturers have long recommended regular maintenance. Only vehicle manufacturers and integrators claim the boxes are 'sealed for life' - but that's just to reduce the maintenance required during warranty period (and hence cost to consumer). After the warranty's expired, they couldn't care less if the box is knackered. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #687445 7th Mar 2024 11:27am
knwatkins
The LR schedule states 160k or 10 years, whichever comes soonest.
The manufacturer of the gearbox (ZF) recommend between 50k and 70k which is much more sensible. Kev
Post #687447 7th Mar 2024 11:49am
caymanblack
From what I have read the best way is to drain the oil , replace the filter and refill with the proper oil ZF Lifeguard I believe and NOT a full flush. overfinch modified
Post #687461 7th Mar 2024 3:03pm
Danb_220_2019
ZF now approve gearbox 'rinsing' (lost in translation from German, I think) as a service action. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #687513 8th Mar 2024 9:17am
CS
This prompted me to look at the German version. The ZF FAQ page talks about "Getriebespuelung" which I would translate as flushing rather than rinsing. They make the point that one should flush with clean approved gearbox oil rather than a flushing agent (they expressly say not to use flushing agents).
As to frequency, they say this depends partly on use and partly on the vehicle manufacturer's spec, with frequent high speed use, towing, sportier driving and a high proportion of short stop-start type use being factors favouring earlier changes. Only Range Rovers since 1988
Post #687523 8th Mar 2024 11:43am
Danb_220_2019
Indeed - the ZF instructions are very clear that only fluid should be used. The last procedure I read vaguely suggested between 60-100K KM between flushes.
I don't speak German, so I've used the phrasing from here:
https://aftermarket.zf.com/en/aftermarket-...ange-kits/ 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #687533 8th Mar 2024 1:21pm
I do our 8sp gearboxes every 30k miles... Never had a failure yet. Thumbs Up
Post #687588 9th Mar 2024 12:11am
