Home > Maintenance & Mods (L322) > E-Diff
Page 1 of 3 123>
beemer5711
Wales
E-Diff
Hi Guys,
I've recently got into a 2012 Westy and I'm looking to change the diff oils, so looking online to buy the correct oil and there is mention of an optional E-diff using different oil.
I'm trying to find out whether I have the optioned E-diff. A quick look online and I came across a Piston Heads thread that said if you put it into snow mode and there is a padlock at the centre diff and the rear diff, then you have to optioned E-diff.
Mine has both padlocks, but is there a more solid way to find out if she has it or not? BMW have a VIN Decoder which tells you all optioned equipment on that VIN. Do we have a similar thing?
Thanks in advance
Post #644772 4th Oct 2022 6:03pm
beemer5711
Wales
Photo of screen showing 2 padlocks.
Post #644773 4th Oct 2022 6:05pm
Sounds like you have one...
If you order the oil from Duckworths they will sell you the right one based on your VIN....
Try this decoder for your vin anyway...
https://www.vindecoderz.com/ Pete
Post #644774 4th Oct 2022 6:08pm
Phoenix
Edit - Already answered.
Post #644775 4th Oct 2022 6:09pm
mjdronfield
I thought they all showed the image of 2 padlocks on the screen, whether the E-Diff was fitted on the rear or not. The only way to tell is if the padlock on the rear axle on the screen actually locks and unlocks or if you look underneath, the E-Diff will have wires going to it.
Mine doesn’t have the diff, and mine is always open on the screen.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #644778 4th Oct 2022 6:20pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Mine has the 2 padlocks on screen and has the open diff. As above wires going to the rear diff is the biggest giveaway 2016 4.4 diesel
Post #644779 4th Oct 2022 6:24pm
beemer5711
Wales
Thanks all for the response. I shall call Duckworth tomorrow.
While I'm there I guess I may as well do the transfer case oil too. I got told you have to reset this afterwards is that correct?
Lastly, sightly random but should my car have TPMS?
Post #644786 4th Oct 2022 6:50pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
On the navi screen the picture is wrong, always show 2 diff locks. But on the speedometer screen it show correct, so if you have both, then both appears. If only one, then rear not appears. Just swich on some special program, snow for example and check this screen.
Post #644787 4th Oct 2022 6:51pm
mjdronfield
Looks like I can concur with the above.
I don’t have it fitted… main screen shows a symbol…
The one near the speedometer doesn’t…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644846 5th Oct 2022 3:22pm
dhallworth
No need to reset the transfer box after an oil change.
Post #644855 5th Oct 2022 5:47pm
beemer5711
Wales
Cheers everyone.
I have checked on the dash and it only has 1 padlock, I will double check underneath when I get a chance, though. I've had a quote from Duckworths and the oil Robin has quoted is for the locking diff and only 2L of oil? I'll query it once I have confirmed what mine has got.
Post #645044 8th Oct 2022 8:49am
garyRR
There you go.
The transfer box oil is TF0753.
The front and rear diff oils are 75W90.
Quantities specified above. 2015 Range Rover Autobiography 4.4 SDV8
Post #645046 8th Oct 2022 8:59am
JayGee
Going to do my diffs and transfer box oils. Had them done year ago when the gearbox was serviced but having just paid for another gearbox service as it wasn’t done properly I don’t trust any of the work now…. 2012 TDV8 Vogue (L322)
Post #645052 8th Oct 2022 9:33am
garyRR
Oil is relatively cheap and one of the best bits of preventative maintenance JayGee. Pick a nice sunny day like today, with someone enlisted to bring you hot drinks and you'll be done in no time. 2015 Range Rover Autobiography 4.4 SDV8
Post #645053 8th Oct 2022 9:36am
jaguar3
And what wast done properly with the gearbox service?
Post #645055 8th Oct 2022 10:08am
Page 1 of 3 123>
