Home > Maintenance & Mods (L322) > E-Diff |
beemer5711 Member Since: 31 Jul 2022 Location: Wales Posts: 72 |
Photo of screen showing 2 padlocks.
4th Oct 2022 6:05pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Sounds like you have one...
4th Oct 2022 6:08pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Edit - Already answered. |
4th Oct 2022 6:09pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I thought they all showed the image of 2 padlocks on the screen, whether the E-Diff was fitted on the rear or not. The only way to tell is if the padlock on the rear axle on the screen actually locks and unlocks or if you look underneath, the E-Diff will have wires going to it.
4th Oct 2022 6:20pm |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 185 |
Mine has the 2 padlocks on screen and has the open diff. As above wires going to the rear diff is the biggest giveaway 2016 4.4 diesel |
4th Oct 2022 6:24pm |
Thanks all for the response. I shall call Duckworth tomorrow.
4th Oct 2022 6:50pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
On the navi screen the picture is wrong, always show 2 diff locks. But on the speedometer screen it show correct, so if you have both, then both appears. If only one, then rear not appears. Just swich on some special program, snow for example and check this screen. |
4th Oct 2022 6:51pm |
Looks like I can concur with the above.
5th Oct 2022 3:22pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3072 |
No need to reset the transfer box after an oil change.
5th Oct 2022 5:47pm |
Cheers everyone.
8th Oct 2022 8:49am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
8th Oct 2022 8:59am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
Going to do my diffs and transfer box oils. Had them done year ago when the gearbox was serviced but having just paid for another gearbox service as it wasn’t done properly I don’t trust any of the work now…. 2012 TDV8 Vogue (L322) |
8th Oct 2022 9:33am |
Oil is relatively cheap and one of the best bits of preventative maintenance JayGee. Pick a nice sunny day like today, with someone enlisted to bring you hot drinks and you'll be done in no time. 2015 Range Rover Autobiography 4.4 SDV8 |
8th Oct 2022 9:36am |
And what wast done properly with the gearbox service? |
8th Oct 2022 10:08am |
