Home > Maintenance & Mods (L322) > E-Diff
Page 2 of 3 <123>
JayGee
They replaced the pan and not just the oil. The pan was leaking. 2012 TDV8 Vogue (L322)
Post #645056 8th Oct 2022 10:14am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
What? Are they put old oil back in gearbox?
Need to change with flush. 10l apr.
Post #645057 8th Oct 2022 10:21am
beemer5711
Wales
You’re supposed to replace the pan and the oil as the pan houses the filter.
Post #645059 8th Oct 2022 10:28am
JayGee
The service last year just drained and filled and kept the old pan. This service drained and filled and replaced the pan. I didn’t want a flush as it’s not recommend by ZF. 2012 TDV8 Vogue (L322)
Post #645060 8th Oct 2022 10:29am
beemer5711
Wales
Oh I see. Yeah I’ve read that a flush can cause more problems than it’s worth.
Post #645061 8th Oct 2022 10:42am
jaguar3
Flush I mean change whole oli, not flush with some special washing liquid. Just get dirty oil off from the system compleatly and replace with new one.
They not recommend use some washing oils due these melt and wash dirt from the system, and bigger particales can stuck in some valves or small channels.
But full oil change they recommend for sure.
Post #645062 8th Oct 2022 10:56am
JayGee
I'm happy with a standard drain and fill. It changes enough oil to prolong the life of the transmission which has a very good reliability record and will probably outlast every other component on these cars. 2012 TDV8 Vogue (L322)
Post #645064 8th Oct 2022 11:11am
mjdronfield wrote:
Looks like I can concur with the above.
I don’t have it fitted… main screen shows a symbol…
The one near the speedometer doesn’t…
And for comparison mine does have one fitted....
 Pete
Post #645278 10th Oct 2022 3:08pm
pcourtney
I don't have e-diff on MY11
All L322's have a low range box and a locking centre diff. BUT the Supercharged models have the rear e-diff (variable electronic locking) as standard and as an option on others. With e-diff the diffs lock automatically and this mode is always active and the electronics lock when it thinks it needs to, you can't override it !
Post #645285 10th Oct 2022 5:32pm
jaguar3
Anyone know exactly with what conditions locks activating? How much wheel should spin before lock activate? Other conditions?
At the moment I know (just with test):
1) Normal driving mode - have no clue are they activating or not.
2) Snow. Seems in this mode the activation speed is fastest.
3) Mud and Sand...it let wheels spin littlebit more before activate locks.
4) Rocks. Diff already lock before car start moving. It release the lock when speed increase or steering wheel is turned out (dont know how many degrees, but not much needed).
Post #645294 10th Oct 2022 6:24pm
mjdronfield
You should see it activating in normal mode on the other dash screen, 4x4 info.
Sounds about right for the other modes. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #645295 10th Oct 2022 6:27pm
GraemeS
The only way to really know when it is being used is to graph live values for it as there is a threshold below which the indicator light stays green. My son graphed his D4's e-diff which showed that it had significant pre-loading for take-off in a straight line yet the indicator stayed green.
Post #645298 10th Oct 2022 7:38pm
beemer5711
Wales
Changed the diffs and transfer case oil today.
Easy enough to do, everything came undone nicely and I replaced the drain plugs when I done them back up.
First up was the transfer case, coming out it looked pretty clean but in the jug it was black!
New oil for comparison.
Next was front diff. A little bit awkward to get the plug back in whilst on your back, not too bad though.
Lastly, rear diff. Nice and easy.
Post #645625 14th Oct 2022 6:42pm
beemer5711
Wales
Thank you. How did you get the digital speed in the speedo please?
Post #645629 14th Oct 2022 7:17pm
mjdronfield
Move the terrain response to rock crawl, at least I think that was the one… display changes automatically.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #645643 14th Oct 2022 8:02pm
Page 2 of 3 <123>
