![]() | Home > Technical (L322) > Central locking auto unlock |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Anyone know if it's possible to code auto unlock with ignition off?
I've done it with a simple timer circuit triggering a relay across the unlock switch - 08MY |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35544 ![]() ![]() |
if you have suto lock on then when you stop you can double pull the door lever to open the door..
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
Its in the menu on the screen on my 2011 m.y 4.4 TDV8. Option to switch it on or off. Steering wheel right hand menu group. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Yes, door lock but not unlock on ignition off. 2015 Range Rover Autobiography 4.4 SDV8 |
Sorry, I thought you wanted to avoid the double pull. Landrover programs the doors to unlock on impact, I found that as I have had trouble with my wife's FL2 key, and auto unlocking during the night and dropping the windows. A new key was the answer. |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
It is possible with an IIDTool… it’s one of the extra setting in the cff settings. I can’t recall which it is offhand, but I’ve done it and works without issue. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
I've checked directly with GAP before who said it's not possible. Unless you know a secret setting they don't? |
It’s definitely possible… I have it enabled on my car.
Found it…
Just to check the build version on your IID?
I’m on 2765 I believe.
I assume you've been a previous Beta tester or had the full CCF granted to you?
Ah yes!
