Home > Technical (L322) > Shift Solenoid 2/Trans Fail Safe on ZF5HP24 gearbox |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 964 |
I could test your solenoid for you, although it’s probably easier just to send you one to swap out and see if the problem disappears (MV2 in the photo). It’s just as likely to be the wiring harness at fault, but substituting the solenoid is a good first step.
2nd Oct 2022 11:56pm |
SLB23 Member Since: 22 Aug 2022 Location: Shropshire Posts: 4 |
Brilliant! How do i go about buying one from yourself? If it was the harness are you able to just swap them out?
3rd Oct 2022 8:00pm |
Yes, the internal wiring harness can be swapped out as well with the transmission in situ. Replacement of the solenoid and the wiring harness are both covered in RAVE so it’s a job that Land Rover even allowed their technicians to do.
3rd Oct 2022 11:27pm |
Fantastic i'll drop a dm now |
4th Oct 2022 9:33pm |
Finally got round to putting the harness & solenoid in the transmission & now it's all fully working as normal. Can finally drive longer than 10 minutes with no warning sounds! Big thanks to Phil for helping & selling me the parts. Onto the rest of the list now! |
16th Oct 2022 9:40pm |
17th Oct 2022 11:24am |
richyx Member Since: 13 Dec 2023 Location: nuneaton Posts: 4 |
sorry for dragging up an old post but ive just come across this and registered to get some info but seems i cant pm you
13th Dec 2023 9:04am |
or if anyone knows where i can get spares for the gearboxes |
13th Dec 2023 8:03pm |
error code im getting is 4 pressure regulator solenoid 4 |
13th Dec 2023 8:04pm |
So, the shift solenoids are the three ‘brown body’ solenoids (MV1, MV2 & MV3) and the pressure regulator solenoids have the black caps (EDS2, EDS3, EDS4 & EDS5).
13th Dec 2023 8:56pm |
ive sent you a pm as well
13th Dec 2023 11:49pm |
