![]() | Home > Technical (L322) > Shift Solenoid 2/Trans Fail Safe on ZF5HP24 gearbox |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
I could test your solenoid for you, although it’s probably easier just to send you one to swap out and see if the problem disappears (MV2 in the photo). It’s just as likely to be the wiring harness at fault, but substituting the solenoid is a good first step.
SLB23 Member Since: 22 Aug 2022 Location: Shropshire Posts: 4 ![]() ![]() ![]() |
Brilliant! How do i go about buying one from yourself? If it was the harness are you able to just swap them out?
Yes, the internal wiring harness can be swapped out as well with the transmission in situ. Replacement of the solenoid and the wiring harness are both covered in RAVE so it’s a job that Land Rover even allowed their technicians to do.
Fantastic i'll drop a dm now |
Finally got round to putting the harness & solenoid in the transmission & now it's all fully working as normal. Can finally drive longer than 10 minutes with no warning sounds! Big thanks to Phil for helping & selling me the parts. Onto the rest of the list now! |
richyx Member Since: 13 Dec 2023 Location: nuneaton Posts: 4 ![]() ![]() |
sorry for dragging up an old post but ive just come across this and registered to get some info but seems i cant pm you
or if anyone knows where i can get spares for the gearboxes |
error code im getting is 4 pressure regulator solenoid 4 |
So, the shift solenoids are the three ‘brown body’ solenoids (MV1, MV2 & MV3) and the pressure regulator solenoids have the black caps (EDS2, EDS3, EDS4 & EDS5).
ive sent you a pm as well
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 988 ![]() ![]() |
Hi Phil
Hi Dave,
