Home > Technical (L322) > Tow bar electrics |
Richycsurfer Member Since: 18 Nov 2018 Location: Plymouth Posts: 44 |
Hi all,
21st Sep 2022 5:18am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1464 |
Wiring
21st Sep 2022 7:21am |
I can highly recommend the Tow Trust bar and if you call their customer support, they're especially helpful. Fitting any tow bar to an L322, please budget an entire day for fitting, especially if you're fitting alone. There's a lot of work involved to fit one but, it's very rewarding when the car is all back together!
21st Sep 2022 8:02am |
Thanks again... I have seen a detachable tow trust in perfect slightly used condition. Has anyone independent used one of these? |
21st Sep 2022 8:08am |
JED Member Since: 08 Jun 2021 Location: Bucks Posts: 16 |
Just to echo GaryRR's comments about fitting a 13-pin and then using an adaptor. You'll be equipped for everything that way.
21st Sep 2022 8:11am |
I'd check a caravanning forum because Tow Trust are a major manufacturer and they have a common detachable fitment across most of their tow bars on all kinds of vehicles.
21st Sep 2022 8:12am |
I will get a 13 pin and adaptor then - seems sound advice.
21st Sep 2022 8:20am |
- Tow trust flange tow bar
21st Sep 2022 8:23am |
Perfect, thanks chaps. Have been considering an IID tool at some point as I'm sure it will pay for itself in a year or two anyway. |
21st Sep 2022 9:06am |
Only thing i've just notcied about the Tow trust rather than the witter is that the tow trust doesn't seem to have an obvious place to secure the breakaway cable? |
21st Sep 2022 9:16am |
It's on the armature.
21st Sep 2022 9:25am |
Thanks Gary, that should be fine then. I usually go through and hook back on itself but not a big issue! |
21st Sep 2022 12:43pm |
