Home > Maintenance & Mods (L322) > How do I get this out?
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Trying to get the floor console stowage box out of my 2008 FFRR.
Obviously there are two torx screws that come out but… the back won’t move!
According to this…
… there should be two clips, but I can’t see anything obvious. Are they hidden? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #642171 6th Sep 2022 12:23pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I took mine out a fair while ago to install the flappy paddle electronics. If i remember correctly, mine just lifted out with a bit of leverage with a screwdriver.
And while you have it out, just check the big plastic tube for the rear heating vents is connected. Mine wasn't when i took mine out. Hope this helps.
Post #642174 6th Sep 2022 12:42pm
tymh
I tried levering it out gently but it seems like there are some sort of clips holding the back down. Don’t want to yank it out in case I break something! Tym
Post #642175 6th Sep 2022 12:49pm
tymh
Solved.
There *are* two notches to disengage at the back.
 Tym
Post #642182 6th Sep 2022 1:19pm
