Home > Maintenance & Mods (L322) > 4 short intake hoses! |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 |
So over the weekend I’ve had the reduced performance pop up on the dash and thanks to this forum have found a split intake pipe on the n/s/r of the doughnut I’ll replace all four as there the older style I’ve gathered from other posts.
31st Aug 2022 8:29pm |
Thank you for your reply. So I’m best off just getting some straight pipe and cutting 4 55mm pieces then. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
31st Aug 2022 8:52pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
That's what I did at a fraction of the cost of new genuine hoses. |
1st Sep 2022 10:04am |
Pipe arrived today so the weekends job is all set to go. If the weather holds out Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
5th Sep 2022 6:50pm |
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 104 |
@RRV78 Did you buy straight pipe, if so do you have a link?? Cheers, Steven.
6th Sep 2022 4:12pm |
https://www.ebay.co.uk/itm/195144378435?mk...media=COPY
6th Sep 2022 4:40pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 282 |
I’ve just fitted the Land Rover ones I bought a while back and they seem quite a bit shorter than the old ones - I hope there’s enough grippage. |
6th Sep 2022 5:15pm |
@RRV78 Ordered! Many thanks... another wee 'to-do' coming up... Cheers, Steven.
6th Sep 2022 9:42pm |
