![]() | Home > Technical (L405) > 4.4SDV8 vibration at 1300rpm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1306 ![]() ![]() ![]() |
Can you 'feel' the vibration or is it just a noise? |
shiversaint Member Since: 16 Aug 2021 Location: Sussex Posts: 9 ![]() ![]() ![]() |
Can't be felt through the steering wheel.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
I’ve just looked into what sounds very similar to yours on my brother in law’s sport which has the 4.4 SDV8.
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Hi, remove under car bash plate and there is a heat shield above the catalytic convertor it will be cracked.
FF777 Member Since: 21 Jan 2022 Location: London Posts: 17 ![]() ![]() ![]() |
Hi, check out the thread below see if your experiencing the same issue, I'm still trying to figure it out, are you getting the vibration only in gear or under any circumstance around 1300rpm?
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
I had the rattle at 1350rpm.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
We find the most common issue is the heat shield under the gearbox sump... The H shaped steel bracket crack fractures leading to the dreaded resonance!!!
It was indeed the heat sheild under the gearbox! |
Glad you found and got
