Home > Technical (L405) > 4.4SDV8 vibration at 1300rpm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1254 |
Can you 'feel' the vibration or is it just a noise? |
31st Aug 2022 11:21am |
shiversaint Member Since: 16 Aug 2021 Location: Sussex Posts: 9 |
Can't be felt through the steering wheel.
31st Aug 2022 11:33am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 460 |
I’ve just looked into what sounds very similar to yours on my brother in law’s sport which has the 4.4 SDV8.
31st Aug 2022 11:51am |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
Hi, remove under car bash plate and there is a heat shield above the catalytic convertor it will be cracked.
31st Aug 2022 9:41pm |
FF777 Member Since: 21 Jan 2022 Location: London Posts: 17 |
Hi, check out the thread below see if your experiencing the same issue, I'm still trying to figure it out, are you getting the vibration only in gear or under any circumstance around 1300rpm?
10th Sep 2022 11:20pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I had the rattle at 1350rpm.
11th Sep 2022 7:41am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
We find the most common issue is the heat shield under the gearbox sump... The H shaped steel bracket crack fractures leading to the dreaded resonance!!!
11th Sep 2022 7:50am |
It was indeed the heat sheild under the gearbox! |
5th Nov 2022 1:19pm |
Glad you found and got
5th Nov 2022 5:18pm |
