![]() | Home > Maintenance & Mods (L322) > TDV8 4.4 Engine Cover Foam |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
My foam is OK but the cover is badly smashed, looks like someone took it off, put it on the ground and then stood on it..!!
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The engine diagrams show the whole cover as a single piece. The part number is LR038152.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
I would suggest you remove the foam as soon as possible because it makes a right mess of all the nooks and crannies in your engine bay. Took me a while to hoover it all out.
Adrian 15 Member Since: 14 Feb 2021 Location: Norfolk Posts: 39 ![]() ![]() ![]() |
That looks really smart, and I expect it protects the pipe work and helps deaden the noise. I will look into it.
If you're going down that route, search on eBay "engine sound absorber". You can buy sheets of the foam and stick it to the engine cover. 2015 Range Rover Autobiography 4.4 SDV8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1269 ![]() ![]() ![]() |
Sorry to hijack this thread but has anybody got the sound deadening on the underneath engine tray?
There is on mine but it's not foam. 2012 TDV8 Vogue (L322) |
I used similar to this, but 1m wide 1.5 long
Thank you for your info, I will look into it
