Home > Maintenance & Mods (L322) > TDV8 4.4 Engine Cover Foam
Adrian 15
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Hello
Just had a look under the engine cover of my TDV8 4.4 and I noticed the foam insert is starting to crumble, I don’t suppose anyone knows if these can be obtained or would it be cheaper to buy the whole cover or is that not available
Any advice would be much appreciated Range Rover Vogue SE 4.4 TDV8
Post #640396 21st Aug 2022 3:00pm
My foam is OK but the cover is badly smashed, looks like someone took it off, put it on the ground and then stood on it..!!
A new one is around £150.... It's LR038152
If you decide to get a new one I will buy your old one if it isn't broken anywhere.. Thumbs Up Pete
Post #640399 21st Aug 2022 3:36pm
garyRR
The engine diagrams show the whole cover as a single piece. The part number is LR038152.
It shows as not overly expensive - £150 from main dealer and is available from factory order. 2015 Range Rover Autobiography 4.4 SDV8
Post #640400 21st Aug 2022 3:40pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I would suggest you remove the foam as soon as possible because it makes a right mess of all the nooks and crannies in your engine bay. Took me a while to hoover it all out.
It can be replaced with no foam or you can do as I did and added sticky backed 10mm foil covered foam.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #640448 21st Aug 2022 11:20pm
Adrian 15
That looks really smart, and I expect it protects the pipe work and helps deaden the noise. I will look into it.
I agree about the old foam bloody stuff gets everywhere
Could I ask where you got it from? Range Rover Vogue SE 4.4 TDV8
Post #640457 22nd Aug 2022 5:08am
garyRR
If you're going down that route, search on eBay "engine sound absorber". You can buy sheets of the foam and stick it to the engine cover. 2015 Range Rover Autobiography 4.4 SDV8
Post #640462 22nd Aug 2022 7:45am
kevinp
Sorry to hijack this thread but has anybody got the sound deadening on the underneath engine tray?
I'm sure I saw some on one of 'Sam's motor and machines' video.
Post #640508 22nd Aug 2022 1:31pm
JayGee
There is on mine but it's not foam. 2012 TDV8 Vogue (L322)
Post #640510 22nd Aug 2022 1:41pm
bigbo
I used similar to this, but 1m wide 1.5 long
https://www.ebay.co.uk/itm/394198639158?ha...R86fxOLYYA
I also used aluminium tape to tidy the edges similar to this
https://www.ebay.co.uk/itm/195245023360?ha...BMmLTj4thg
As For the under tray mine has nothing in it.
MG TF 2003
Post #640526 22nd Aug 2022 3:35pm
Adrian 15
Thank you for your info, I will look into it
Cheers Range Rover Vogue SE 4.4 TDV8
Post #640590 23rd Aug 2022 9:32am
