Home > Maintenance & Mods (L322) > TDV8 4.4 Engine Cover Foam |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
My foam is OK but the cover is badly smashed, looks like someone took it off, put it on the ground and then stood on it..!!
21st Aug 2022 3:36pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
The engine diagrams show the whole cover as a single piece. The part number is LR038152.
21st Aug 2022 3:40pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 570 |
I would suggest you remove the foam as soon as possible because it makes a right mess of all the nooks and crannies in your engine bay. Took me a while to hoover it all out.
21st Aug 2022 11:20pm |
Adrian 15 Member Since: 14 Feb 2021 Location: Norfolk Posts: 39 |
That looks really smart, and I expect it protects the pipe work and helps deaden the noise. I will look into it.
22nd Aug 2022 5:08am |
If you're going down that route, search on eBay "engine sound absorber". You can buy sheets of the foam and stick it to the engine cover. 2015 Range Rover Autobiography 4.4 SDV8 |
22nd Aug 2022 7:45am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
Sorry to hijack this thread but has anybody got the sound deadening on the underneath engine tray?
22nd Aug 2022 1:31pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3193 |
There is on mine but it's not foam. 2012 TDV8 Vogue (L322) |
22nd Aug 2022 1:41pm |
I used similar to this, but 1m wide 1.5 long
22nd Aug 2022 3:35pm |
Thank you for your info, I will look into it
23rd Aug 2022 9:32am |
