![]() | Home > Maintenance & Mods (L322) > Engine chirp when cold |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I had another look at this over the weekend. I cannot pin point the chirp, but it certainly sounds like it’s near the alternator.
I had my belt and tensioner changed last week and oh what joy |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
My culprit was the idle pulley that sits on the bracket at top left of the engine. Bearing was shot Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
Mine squeaks of a morning yet all pulleys, the tensioner and both belts were replaced a few months ago. It sounds like a failing bearing in a small pulley. |
Squirt some water on the belt - this will tell you straight away if it's a tensioner bearing or not 2012 TDV8 Vogue (L322) |
I intend doing that if I think of it when not on my way out.
Hi JayGee, I finally got to try this, and a wet belt takes away the squeal temporary. This suggests the belt is contaminated? If that is the case then would a good spray of degreaser on the belt help? Plenty so it covers all of the belt and pulleys? Or is there no point and just needs to be replaced? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Worth trying brake cleaner but it didn’t fix mine. It could also be the tensioner not putting enough force on the belt to create enough friction. As I had both changed I never knew.. 2012 TDV8 Vogue (L322) |
No time like the present!
The noise always returned the next morning with mine. Got the garage to change the belt and tensioner but they did clean up the mess left by the belt dressing I’d used |
So far so good…
It’s not quite the magic fix I’d like… closer, but not perfect.
Jmagg73 Member Since: 16 Jan 2021 Location: Illinois Posts: 33 ![]() ![]() ![]() |
This happens to my 2011. It only happens when it's very very very cold. Will go away in 15 minutes. Doesn't happen any other time of the year. |
