![]() | Home > Maintenance & Mods (L322) > Engine chirp when cold |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I have a chirp from the engine bay when cold, and usually disappears when warned up.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Just been reading up on this, new to me, engine.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
I had same. The top left pulley had gone badly. Its the one at extreme top left looking at engine Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
https://www.advancedfactors.co.uk/auxiliar...1791-c.asp
Rob, he said he changed all the pulleys for genuine ones last year.... Pete
That describes mine all too well.
AFAIK fan and shroud have to come out - big job 2012 TDV8 Vogue (L322) |
Spray some water on the belt and if the noise goes away it's the belt and not an imminent problem. If the noise persists then it could be a bearing which you need to sort ASAP as it can fail and it will take out the belt. 2012 TDV8 Vogue (L322) |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
mine (2012 4.4TDV8) chirps when cold - most years it goes away in spring but this year it still happens a bit, especially on cooler days. I have had the belt tensioner mod done too. 2012 L322 4.4 TDV8 AB low mileage - a peach
Cheers JayGee. I’ll give that a go and will prioritise accordingly. |
I wasn't aware of a 'mod' either and thought it was just replace when it's worn or belt is running off the edge. 2012 TDV8 Vogue (L322) |
LR022810 is the idler pulley tensioner upgrade.
Interesting…
