Home > Maintenance & Mods (L322) > Engine chirp when cold
Page 2 of 3 <123>
JayGee
I'm going to have to check my receipt for the work done as they may have just changed the pulley on the tensioner and not the tensioner itself. A weak tensioner would certainly be a root cause of slight belt slippage when the belt is cold. 2012 TDV8 Vogue (L322)
Post #640811 25th Aug 2022 6:58am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I had another look at this over the weekend. I cannot pin point the chirp, but it certainly sounds like it’s near the alternator.
I have visually examined everything touching the aux belt and see no signs of movement or wobble.
My next step is to remove the fan and cowling to be able to gain better access. It’s a ball ache… but not much choice really. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #645349 11th Oct 2022 12:18pm
JayGee
I had my belt and tensioner changed last week and oh what joy Rolling with laughter - no belt noise on startup in the morning. No idea if it was the tensioner gone weak or belt contamination and neither did the garage but it's fixed after putting up with it for nearly a year. 2012 TDV8 Vogue (L322)
Post #645354 11th Oct 2022 12:22pm
DrRob
My culprit was the idle pulley that sits on the bracket at top left of the engine. Bearing was shot Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #645359 11th Oct 2022 12:39pm
GraemeS
Mine squeaks of a morning yet all pulleys, the tensioner and both belts were replaced a few months ago. It sounds like a failing bearing in a small pulley.
Post #645403 11th Oct 2022 8:53pm
JayGee
Squirt some water on the belt - this will tell you straight away if it's a tensioner bearing or not 2012 TDV8 Vogue (L322)
Post #645414 12th Oct 2022 7:59am
GraemeS
I intend doing that if I think of it when not on my way out.
Edit: Mine's noise is caused by the belt. It has a short wobble section, presumably at the join, which is interfering with the smooth passage over 1 pulley. I haven't determined exatly which pulley yet but I suspect a smooth one that runs on the back of the belt.
Post #645422 12th Oct 2022 9:50am
Ffrr-lover
Hi JayGee,
I finally got to try this, and a wet belt takes away the squeal temporary. This suggests the belt is contaminated?
If that is the case then would a good spray of degreaser on the belt help? Plenty so it covers all of the belt and pulleys? Or is there no point and just needs to be replaced? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #647615 7th Nov 2022 6:37pm
JayGee
Worth trying brake cleaner but it didn’t fix mine. It could also be the tensioner not putting enough force on the belt to create enough friction. As I had both changed I never knew.. 2012 TDV8 Vogue (L322)
Post #647617 7th Nov 2022 6:42pm
Ffrr-lover
No time like the present!
Just been and given the belt a liberal dosing of degreaser. As soon as the first squirt hit the belt the noise disappeared. It was a blissful diesel grumble. I let the engine run for a bit to get in all parts of the components, and now to sit for a night. I’ll try repeating over the next few days to see how I get on.
If not, I will plant to dismantle to gain access, remove the belt, see what parts look good or bad and then go from there.
@JayGee, did you clean anything before fitting your new belt? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #647624 7th Nov 2022 7:24pm
JayGee
The noise always returned the next morning with mine. Got the garage to change the belt and tensioner but they did clean up the mess left by the belt dressing I’d used Embarassed 2012 TDV8 Vogue (L322)
Post #647626 7th Nov 2022 7:31pm
Ffrr-lover
So far so good…
Last night I took the car out and there was no squeal!
Let’s see how it goes over the next few weeks… if I need to spray it every so often, I’ll put up with that until the warmer weather returns next year!
At least this suggests belt contamination rather that a problem pulley or bracket Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #647742 9th Nov 2022 7:22am
JayGee
Thumbs Up 2012 TDV8 Vogue (L322)
Post #647745 9th Nov 2022 8:20am
Ffrr-lover
It’s not quite the magic fix I’d like… closer, but not perfect.
Starting the car is fine. Nothing but the normal TDV8 grumble. As I drive down the road with the still cold engine, I get 20 meters and a squeal returns but less intense than before and is only there above 1,500 rpm. I stop at the end of my road it goes, then squeals as I pull away.
Less than a mile into my journey and all is good again. It’s just that initial cold start and only above a gentle squeeze of the go pedal.
I’m continuing to spray with degreaser, but only use the car once or twice a week now so it’s not forefront of my mind therefore I often forget until that 20m point. When I do use it, all is good for a couple of days or journeys.
Oh, and the bottle of degreaser is ironically covered in oil… I don’t want to get my hands dirty Laughing Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #648217 16th Nov 2022 7:46am
Jmagg73
United States 2011 Range Rover HSE 4.4 V8 Stornoway Grey
This happens to my 2011. It only happens when it's very very very cold. Will go away in 15 minutes. Doesn't happen any other time of the year.
Post #648397 18th Nov 2022 4:34am
Page 2 of 3 <123>
