![]() | Home > Maintenance & Mods (L322) > Coolant Level Sensor operation 4.4TDV8 2011 |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 ![]() ![]() ![]() |
Does anybody known how the coolant sensor works ?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Many moons ago Nino- Nino bench tested his to prove that not only does it check coolant level but also gives different results depending on the specific gravity of the coolant , thus alarming with water but not antifreeze of the correct mix.
The probe does not have any physical contact with the coolant fluid. The probe is sited up in to an unsealed tube void in the bottom of the expansion tank, so it’s i’d be surprised if it could be variable resistance based. It might be a magnetic reed switch in the probe (it’s the correct shape for that also) with a float in the tank that operates the reed switch. The float could operate on fluid level but perhaps also operate based on specific gravity of the fluid.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic43284.html 2012 TDV8 Black Edition
Great explanation. Many thanks for posting the link. -------------------------------------
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I now have this problem
It’s quite an easy / cheap job to replace the coolant tank. I don’t think it’s worth removing and cleaning it. -------------------------------------
Thank you, anyone got part number(s) by chance ?
This is the one I ordered.
amazing thank you bwelton
Yes, includes Sensor, Coolant Tank and Lid. -------------------------------------
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 ![]() ![]() ![]() |
I got mine from site sponsor Advanced Factors with our discount code AF4LRP ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Thanks DrRob
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1261 ![]() ![]() ![]() |
I paid more than twice that price for a genuine one but that was my choice.
