Home > Maintenance & Mods (L322) > Coolant Level Sensor operation 4.4TDV8 2011 |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 |
Does anybody known how the coolant sensor works ?
20th Aug 2022 5:09pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
Many moons ago Nino- Nino bench tested his to prove that not only does it check coolant level but also gives different results depending on the specific gravity of the coolant , thus alarming with water but not antifreeze of the correct mix.
20th Aug 2022 7:24pm |
The probe does not have any physical contact with the coolant fluid. The probe is sited up in to an unsealed tube void in the bottom of the expansion tank, so it’s i’d be surprised if it could be variable resistance based. It might be a magnetic reed switch in the probe (it’s the correct shape for that also) with a float in the tank that operates the reed switch. The float could operate on fluid level but perhaps also operate based on specific gravity of the fluid.
21st Aug 2022 7:10am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
https://www.fullfatrr.com/forum/topic43284.html 2012 TDV8 Black Edition
21st Aug 2022 7:52am |
Great explanation. Many thanks for posting the link. -------------------------------------
21st Aug 2022 8:34am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
I now have this problem
20th Dec 2022 6:19pm |
It’s quite an easy / cheap job to replace the coolant tank. I don’t think it’s worth removing and cleaning it. -------------------------------------
20th Dec 2022 6:32pm |
Thank you, anyone got part number(s) by chance ?
20th Dec 2022 7:59pm |
This is the one I ordered.
20th Dec 2022 8:50pm |
amazing thank you bwelton
20th Dec 2022 9:32pm |
Yes, includes Sensor, Coolant Tank and Lid. -------------------------------------
20th Dec 2022 10:10pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
I got mine from site sponsor Advanced Factors with our discount code AF4LRP Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
21st Dec 2022 7:29am |
Thanks DrRob
21st Dec 2022 10:02am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
I paid more than twice that price for a genuine one but that was my choice.
21st Dec 2022 10:44am |
