Home > Maintenance & Mods (L322) > Coolant Level Sensor operation 4.4TDV8 2011
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Does anybody known how the coolant sensor works ?
I’ve had an intermittent coolant level problem for some months and finally got around to changing the collect expansion tank. In doing so the coolant level sensor popped out of the holder on the new tank. I refitted it but was surprised by what it looks
Like and so am puzzled how it works.
BTW - I followed this excellent video for the method.
Attached are photos of the old tank and old sensor.
MY 2012 4.4 TDV8
Post #640319 20th Aug 2022 6:09pm
garyRR
Depending on how much coolant is in the expansion tank, the resistance of the probe changes. The car measures the resistance change and flags an error when empty. 2015 Range Rover Autobiography 4.4 SDV8
Post #640328 20th Aug 2022 7:09pm
Baltic Blue
Many moons ago Nino- Nino bench tested his to prove that not only does it check coolant level but also gives different results depending on the specific gravity of the coolant , thus alarming with water but not antifreeze of the correct mix.
Sorry I can’t remember any more details or find the post.
Post #640335 20th Aug 2022 8:24pm
bwelton
The probe does not have any physical contact with the coolant fluid. The probe is sited up in to an unsealed tube void in the bottom of the expansion tank, so it’s i’d be surprised if it could be variable resistance based. It might be a magnetic reed switch in the probe (it’s the correct shape for that also) with a float in the tank that operates the reed switch. The float could operate on fluid level but perhaps also operate based on specific gravity of the fluid.
I’m still wondering how / why it could operate intermittently. -------------------------------------
MY 2012 4.4 TDV8
Post #640351 21st Aug 2022 8:10am
nino_nino
https://www.fullfatrr.com/forum/topic43284.html 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #640353 21st Aug 2022 8:52am
bwelton
Great explanation. Many thanks for posting the link. -------------------------------------
MY 2012 4.4 TDV8
Post #640358 21st Aug 2022 9:34am
GGDR
I now have this problem
So Nino you just cleaned the tank and sensor and re-fitted?
. Cheers, Greg
Post #651280 20th Dec 2022 7:19pm
bwelton
It’s quite an easy / cheap job to replace the coolant tank. I don’t think it’s worth removing and cleaning it. -------------------------------------
MY 2012 4.4 TDV8
Post #651282 20th Dec 2022 7:32pm
GGDR
Thank you, anyone got part number(s) by chance ?
. Cheers, Greg
Post #651296 20th Dec 2022 8:59pm
bwelton
This is the one I ordered.
https://www.lrjdirect.co.uk/product/expansion-tank-lr022731 -------------------------------------
MY 2012 4.4 TDV8
Post #651307 20th Dec 2022 9:50pm
GGDR
amazing thank you bwelton
it looks like it has the sensor in it?
. Cheers, Greg
Post #651317 20th Dec 2022 10:32pm
bwelton
Yes, includes Sensor, Coolant Tank and Lid. -------------------------------------
MY 2012 4.4 TDV8
Post #651321 20th Dec 2022 11:10pm
DrRob
I got mine from site sponsor Advanced Factors with our discount code AF4LRP Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #651330 21st Dec 2022 8:29am
GGDR
Thanks DrRob
So are we saying non-original is ok in this case?
. Cheers, Greg
Post #651345 21st Dec 2022 11:02am
kevinp
I paid more than twice that price for a genuine one but that was my choice.
If pattern ones are holding up OK without problems then I don't see why not.
How many companies go to the trouble of making such a complicated part? Probably the same ones that supply Land Rover in the first place so we pay over the top for a 'genuine one'.
Post #651352 21st Dec 2022 11:44am
