Home > Maintenance & Mods (L322) > While we are down there..... |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3176 |
check/replace tensioners. |
17th Aug 2022 3:45pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Starter motor
17th Aug 2022 3:51pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
Thanks!
18th Aug 2022 7:39am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
The expansion tank only needs replacing if it’s been contaminated by oil from a leaking oil cooler. Gearbox and diff fluid does not need access from the front of the engine. Not sure about the EGT sensors. 2012 TDV8 Vogue (L322) |
18th Aug 2022 8:06am |
Appreciate all the replies. My question was more intended with regards to the front of the engine already being out, if there are any obvious things to do - belts and tensioners being one of them. RR Vogue 4.4 TDV8 - 11
18th Aug 2022 8:30am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Water pump is relatively cheap, I'd do it when access is easy. |
18th Aug 2022 8:32am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1231 |
Just done all my pulleys and water pump as a precaution. I used Genuine items only though. Had a pattern part sent by mistake and it had more play in it than the one I was replacing. |
18th Aug 2022 9:59am |
