![]() | Home > Maintenance & Mods (L322) > While we are down there..... |
check/replace tensioners. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Starter motor
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Thanks!
The expansion tank only needs replacing if it’s been contaminated by oil from a leaking oil cooler. Gearbox and diff fluid does not need access from the front of the engine. Not sure about the EGT sensors. 2012 TDV8 Vogue (L322) |
Appreciate all the replies. My question was more intended with regards to the front of the engine already being out, if there are any obvious things to do - belts and tensioners being one of them. RR Vogue 4.4 TDV8 - 11
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
Water pump is relatively cheap, I'd do it when access is easy. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1269 ![]() ![]() ![]() |
Just done all my pulleys and water pump as a precaution. I used Genuine items only though. Had a pattern part sent by mistake and it had more play in it than the one I was replacing. |
