Home > Maintenance & Mods (L322) > Headrest interchangeability back to front |
2010BlackL322 Member Since: 30 Oct 2021 Location: London Posts: 119 |
Hello Everyone.
13th Aug 2022 10:21am |
Thank you! So I’m not crazy
14th Aug 2022 11:28am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
How much did it cost to have the front headrests converted to winged (if I'm understanding correctly)? 2015 Range Rover Autobiography 4.4 SDV8 |
14th Aug 2022 1:06pm |
14th Aug 2022 2:10pm |
They come as standard on the rear seats that recline. Check out my YouTube channel https://youtu.be/UHBbLWZXw4A |
14th Aug 2022 2:11pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
I put the rears in the front of my old 322 by stripping them apart and re engineering the front posts to work in the rear headrests and voila!
14th Aug 2022 2:22pm |
The newer models 10-12 are slightly easier, as the posts are almost the same distance apart, they need some encouragement to put the fronts in the rears. Mine had screens in the fronts, I’ve never used them, so no big deal they are back there and out of sight, the comfort of those softer wing backs are superb, on long runs, will be massive benefit to reducing fatigue when driving long hours.
14th Aug 2022 2:38pm |
If you want to know how to switch over the headrests, it’s in this video. Going live at 6pm BST 17th Aug
17th Aug 2022 3:43pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Been thinking of this for weeks. I changed my seats out, and gained rear screens, which obviously can’t work. But kept the outgoing seat rear headrests, so I can switch the posh winged ones to the front on the newer seats, , and use the old rears in the rear! Watching Mark’s vid, he says the tips can rest in the green ‘sockets’ and can be pushed down when needed…. I wonder if when I do mine, I could araldite the strut tips to the green sockets, and then with a few cable straps around the struts, then add some more glue to build up the contact area. I’d never raise them, but maybe when cleaning the seats, I might knock them, and they won’t sit right, and then tilt forward and back, if not in the ‘sockets’?
17th Aug 2022 8:09pm |
I have since pulled apart the drivers seat back, araldited the bottom of the headrest into the green motor feet / caps, the drivers headrest goes up and down on the button just fine, no issues.
17th Aug 2022 9:05pm |
P.s… I remember being told they are not called heat rests, they are head restraints, and shouldn’t be comfortable, as could lead to dozing, and also they must be adjusted to be level with height of your ears, to the top of restraint. For when you get rear ended on a fast road. -people put them down, for reversing etc. as per driving instructor no less.[/quote]
17th Aug 2022 9:06pm |
Nob off!
17th Aug 2022 11:37pm |
