![]() | Home > Maintenance & Mods (L322) > Fuse for dash cam |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The heated steering wheel fuse for the front one.
On a Td6 2004 all the fuses on the rear fuse board are permanently live. There is however a 0.5mm² green / yellow cable in the harness above the rear fuse board which is ignition switched. You could connect into this cable, fit a fuse carrier with a suitable fuse and thus serve your camera.
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
Thank you very much, so the front fuse box sounds better
