Home > Maintenance & Mods (L322) > Fuse for dash cam |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
The heated steering wheel fuse for the front one.
15th Aug 2022 5:32am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
On a Td6 2004 all the fuses on the rear fuse board are permanently live. There is however a 0.5mm² green / yellow cable in the harness above the rear fuse board which is ignition switched. You could connect into this cable, fit a fuse carrier with a suitable fuse and thus serve your camera.
15th Aug 2022 6:50am |
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 |
Thank you very much, so the front fuse box sounds better
15th Aug 2022 8:02am |
