Home > Maintenance & Mods (L322) > Fuse for dash cam
sergeiicz
Czech Republic 2002 Range Rover HSE Td6 Epsom Green
Fuse for dash cam
Hi, which fuse (rear fuse box) is switched on and off with the key, or which fuse is suitable for connecting a dash cam?
Found this:
1 audio amp
3 parking aid, blind spot monitor rear view camera
4 rear air con
14 rear blower motor
15 rear screen wiper
20 rear seat heaters...
Can anyone please confirm?
L322 2004
Thank you
Post #639621 14th Aug 2022 10:57pm
garyRR
The heated steering wheel fuse for the front one.
https://www.fullfatrr.com/forum/post602206.html#602206
For the rear, seems Vanity mirror is the one to look for.
https://www.fullfatrr.com/forum/topic27439.html 2015 Range Rover Autobiography 4.4 SDV8
Post #639628 15th Aug 2022 5:32am
On a Td6 2004 all the fuses on the rear fuse board are permanently live. There is however a 0.5mm² green / yellow cable in the harness above the rear fuse board which is ignition switched. You could connect into this cable, fit a fuse carrier with a suitable fuse and thus serve your camera.
The cable is protected by Fuse2 5A on the front fuse board.
Post #639633 15th Aug 2022 6:50am
sergeiicz
Thank you very much, so the front fuse box sounds better
edit - works like a charm, thanks a lot!
Post #639642 15th Aug 2022 8:02am
