Home > Maintenance & Mods (L322) > Air Con problem |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
Known issue mate, valve in the compressor
27th Jul 2022 4:38pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Sounds like the valve. New compressor time.
27th Jul 2022 5:00pm |
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 |
Just noticed it’s been gassed up to the 4 zone not dual so that’s definitely not helping… thanks for the links guys just reading up on it now !! I guess I need to just order a new compressor ! |
27th Jul 2022 5:20pm |
If the refrigerant has been overcharged, get that corrected first and see if it improves. |
27th Jul 2022 5:24pm |
It’s been over charged today - 611g recovered 890g charged,
27th Jul 2022 5:30pm |
Overcharge will stop it working. They need to redo it so it has the right amount, as per the label under the bonnet.
27th Jul 2022 6:19pm |
Thanks so much guys , will get the right amount in it and see where I’m at , will start putting the penny’s away for a new compressor lol |
27th Jul 2022 6:21pm |
I’ve not seen an answer yet as to whether replacing with the same make unit will mean that you will have the same issue again eventually, or whether the part has been upgraded… or whether a different make compressor won’t have the known issue like the factory one.
27th Jul 2022 6:30pm |
It’s on its original one , so lasted 10yrs… I imagine in another 10 years the air con will be the least of my problems lol
27th Jul 2022 6:32pm |
Yeah, but you have to take the compressor off to change the valve, so most folk do the whole compressor in case that has an issue soon after the valve swap.
27th Jul 2022 6:45pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Please search the forum - there must have been 3 or 4 threads all on exactly the same thing in the last month. You need to remove the compressor in order to access the valve, in which case it's worthwhile replacing the compressor anyway, being 10 years old and how big of a job it is to get to. New compressors come with a new valve. Here's the DIY guide I wrote for the benefit of other members: https://www.fullfatrr.com/forum/topic63889.html 2015 Range Rover Autobiography 4.4 SDV8 |
27th Jul 2022 8:30pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
I was fearing my compressor might be at fault but had the system recharged today. For £60 I thought it was worth doing before investigating further. The system had 465 whatever's in it and now has 700 whatever's in and it is now, dare I say toooo coooold!!!!
10th Aug 2022 9:57am |
Yep. That worked for me. For a few months then compressor needed doing. I hope yours stays cold Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
10th Aug 2022 10:42am |
Thanks Rob. Fingers crossed. My compressor was meant to have been done just before I bought the car 3 years ago. |
10th Aug 2022 11:02am |
