Home > Maintenance & Mods (L322) > Air Con problem
longd
Air Con problem
2012 Range Rover 4.4tdv8
Hey guys,
the air con in my wagon is acting up ,
I’ve recharged the gas it was a little low but no leaks etc
It’s still not blowing cold ,
Any suggestions on what to look at next ?
Post #637936 27th Jul 2022 3:47pm
mjdronfield
Known issue mate, valve in the compressor
https://www.fullfatrr.com/forum/topic43778...ed+air+con
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #637949 27th Jul 2022 4:38pm
DrRob
Sounds like the valve. New compressor time.
Plenty of info including a diy guide on here. Best using the Search function Thumbs Up
Buy it from site sponsor Advanced Factors using our code, AF4LRP. Same as LR main stealer but 50% less Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #637950 27th Jul 2022 5:00pm
longd
Just noticed it’s been gassed up to the 4 zone not dual so that’s definitely not helping… thanks for the links guys just reading up on it now !! I guess I need to just order a new compressor !
Post #637952 27th Jul 2022 5:20pm
Phoenix
If the refrigerant has been overcharged, get that corrected first and see if it improves.
Post #637953 27th Jul 2022 5:24pm
longd
It’s been over charged today - 611g recovered 890g charged,
When we had the heatwave last Monday air con started blowing out hot air after an hour driving ? Also passenger side blowing out colder than driver side. Then intermittently blowing out cold air but mainly hot air .
I also noticed that it was taking a while to start blowing cold air prior to all this …
Assumed it needed recharge and got it booked in today.
Post #637954 27th Jul 2022 5:30pm
mjdronfield
Overcharge will stop it working. They need to redo it so it has the right amount, as per the label under the bonnet.
Then you will probably find you still have the valve issue with the compressor, but then when it does come on, it should blow nice and cold.
When it’s not come on and should, you might find getting the revs up makes it come on.
Not ideal I know….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #637962 27th Jul 2022 6:19pm
longd
Thanks so much guys , will get the right amount in it and see where I’m at , will start putting the penny’s away for a new compressor lol
Post #637963 27th Jul 2022 6:21pm
mjdronfield
I’ve not seen an answer yet as to whether replacing with the same make unit will mean that you will have the same issue again eventually, or whether the part has been upgraded… or whether a different make compressor won’t have the known issue like the factory one.
Might have missed it of course…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #637964 27th Jul 2022 6:30pm
longd
It’s on its original one , so lasted 10yrs… I imagine in another 10 years the air con will be the least of my problems lol
Though I have been reading up on it and some people have had the problem come back again within a couple of years !!
Also reading up on just replacing the valve
Post #637965 27th Jul 2022 6:32pm
mjdronfield
Yeah, but you have to take the compressor off to change the valve, so most folk do the whole compressor in case that has an issue soon after the valve swap.
Mine was just over 4 years old when I bought it. Had the issue then….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #637967 27th Jul 2022 6:45pm
garyRR
Please search the forum - there must have been 3 or 4 threads all on exactly the same thing in the last month.
You need to remove the compressor in order to access the valve, in which case it's worthwhile replacing the compressor anyway, being 10 years old and how big of a job it is to get to. New compressors come with a new valve.
Here's the DIY guide I wrote for the benefit of other members: https://www.fullfatrr.com/forum/topic63889.html 2015 Range Rover Autobiography 4.4 SDV8
Post #637978 27th Jul 2022 8:30pm
kevinp
I was fearing my compressor might be at fault but had the system recharged today. For £60 I thought it was worth doing before investigating further. The system had 465 whatever's in it and now has 700 whatever's in and it is now, dare I say toooo coooold!!!!
So for anyone thinking about changing the compressor it might be worth the gamble of a recharge first.
Post #639166 10th Aug 2022 9:57am
DrRob
Yep. That worked for me. For a few months then compressor needed doing. I hope yours stays cold Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #639169 10th Aug 2022 10:42am
kevinp
Thanks Rob. Fingers crossed. My compressor was meant to have been done just before I bought the car 3 years ago.
Post #639172 10th Aug 2022 11:02am
