Home > Technical (L322) > Is a slight suspension leak normal?
AndrewT
New Zealand 2003 Range Rover Vogue 4.4 V8 Oslo Blue
I've done a search but couldn't find an answer to this so apologies if it's been covered before.
I parked my car up in off-road mode and when I returned to it a short while later one of the front corners had dropped right down suggesting a leak. Is the system completely sealed or is a slight leaking to be expected once the ignition and therefore compressor is switched off?
If so, how long for a drop would be acceptable? I mean, if I left the car for a month then I would expect some dropping to have occured, however an hour or so seems to suggest excessive leaking.
Having not had a car with air suspension before I've got nothing to compare it against. Confused
Post #69282 19th Jun 2011 9:02pm
daveo
i dont have any drop, was park for 2 weeks while on my hols, all ok V8 facelift Range Rover Autobiography 22" wheels.
Post #69283 19th Jun 2011 9:51pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Any drop noticed by eye is too much, especially after just an hour.
but you sure your range rover didnt just level itself, it comes to life to do this now and then. 2004 black Vogue TD6
Post #69287 19th Jun 2011 10:16pm
AndrewT
Fairly sure it didn't just level itself. One corner was noticeably lower even though it was parked on a flat and level surface.
Post #69288 19th Jun 2011 10:19pm
letsavit2
soapy water it is then........ Wink 2004 black Vogue TD6
Post #69289 19th Jun 2011 10:21pm
Would suspect a leak which isnt normal. Could be a bag gone, air line or valve block. Most common is a leaking bag. It can't be to bad as the compressor is keeping up with the leak when running. I guess you don't have an air suspension inactive message on the dash as you got the car to off road height. Take it back to the dealers and push for 2 new struts. Sounds like 1 is goosed but good safe practice to change an axel pair Thumbs Up Or that's what you should insist on.
Post #69291 19th Jun 2011 10:27pm
AndrewT
No warning lights and the car rises at a reasonable rate so smallish leak seems most likely.
Some phone calls to make in the morning.....
Post #69293 19th Jun 2011 10:32pm
AndrewT
Update:
I took it to a local independent this morning and they found a hole in the NSF strut. It must be growing as the front of the car now sits right at the bottom and you can see it dropping as soon as the ignition is off. It's booked in to be replaced next Wednesday.
That means I can't drive it for a week as I don't want to overload the compressor. Big Cry
On the other hand all work has been confirmed as covered under warranty. Mr. Green
Post #69327 20th Jun 2011 12:17pm
Are they doing both? I would press them for both if you can on safety grounds.
Post #69328 20th Jun 2011 12:20pm
AndrewT
I tried but unfortunately it's not strictly a safety issue as the sides are linked so deflation of one will cause deflation of the other. He said the other one was in good condition so perhaps it has already been replaced.
Interestingly he said that he had changed hundreds of OSF ones but only ever 4 NSF.
Post #69335 20th Jun 2011 1:20pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
Perhaps the air bag in itself is not an issue, but it has an integral shock absorber, and they should always be changed in pairs - at least thats what I was always taught Shocked
Post #69852 24th Jun 2011 3:46pm
AndrewT
I didn't realise that the shock absorber is integral to the unit. In that case I'll push for changing both sides.
Thanks for the advice.
Post #69889 24th Jun 2011 9:44pm
Yer there shocks with like an air doughnut round them. Same where in the US you can buy replacement airbags to go on the original shock, there are varied reports and not that much of a saving. Push for both to be done as there £350+/- per corner without labour.
Post #69894 24th Jun 2011 10:16pm
