Home > Technical (L322) > Is a slight suspension leak normal? |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i dont have any drop, was park for 2 weeks while on my hols, all ok V8 facelift Range Rover Autobiography 22" wheels.
19th Jun 2011 10:51pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
Any drop noticed by eye is too much, especially after just an hour.
19th Jun 2011 11:16pm |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 |
Fairly sure it didn't just level itself. One corner was noticeably lower even though it was parked on a flat and level surface. |
19th Jun 2011 11:19pm |
soapy water it is then........ 2004 black Vogue TD6 |
19th Jun 2011 11:21pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Would suspect a leak which isnt normal. Could be a bag gone, air line or valve block. Most common is a leaking bag. It can't be to bad as the compressor is keeping up with the leak when running. I guess you don't have an air suspension inactive message on the dash as you got the car to off road height. Take it back to the dealers and push for 2 new struts. Sounds like 1 is goosed but good safe practice to change an axel pair Or that's what you should insist on. |
19th Jun 2011 11:27pm |
No warning lights and the car rises at a reasonable rate so smallish leak seems most likely.
19th Jun 2011 11:32pm |
Update:
20th Jun 2011 1:17pm |
Are they doing both? I would press them for both if you can on safety grounds. |
20th Jun 2011 1:20pm |
I tried but unfortunately it's not strictly a safety issue as the sides are linked so deflation of one will cause deflation of the other. He said the other one was in good condition so perhaps it has already been replaced.
20th Jun 2011 2:20pm |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 |
Perhaps the air bag in itself is not an issue, but it has an integral shock absorber, and they should always be changed in pairs - at least thats what I was always taught |
24th Jun 2011 4:46pm |
I didn't realise that the shock absorber is integral to the unit. In that case I'll push for changing both sides.
24th Jun 2011 10:44pm |
Yer there shocks with like an air doughnut round them. Same where in the US you can buy replacement airbags to go on the original shock, there are varied reports and not that much of a saving. Push for both to be done as there £350+/- per corner without labour. |
24th Jun 2011 11:16pm |
