![]() | Home > Maintenance & Mods (L322) > Ride height and alignment |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
IMHO 4mm will make no difference at all. In normal setting the suspension only levels to 10m IIRC, you can put it in tight mode for alignment but it doesn’t make much difference in reality..
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
You say alignment was checked recently.
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 38 ![]() ![]() ![]() |
Doubtful the camber and castor was adjusted; not actually sure what went down with last alignment I had a helper go all the way to town and drop the car at the shop, I work from home in a remote location - I can only look at the printed report indicating all to be within range.
