![]() | Home > Maintenance & Mods (L322) > Mood / Ambient lighting |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I had the HVAC sides off today to replace a clicking blend motor and had an idea to fix ElectroLuminecence wire to the edge of the panel to see what it looked like. I had 2x 1mtr lengths in a draw so with a hot glue gun fixed the strip where required and pushed the retaining edge in between the wood trim and edge. Easily connected to the fusebox in the glovebox with an add-a-fuse on an ignition switched location. What do you think, it can just as easily be removed with no trace, I will leave it for the time being. Only a couple of pounds per side and adds a subtle blue glow to the footwell
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
The jury is out on the light but tell me more about your mats... |
Had them custom-made via Aliexpress. Diamond quiled, lots of colourways. they are great and cheap enough. seem to be very durable and easy to clean. there are loads of sellers, chose one who will add a logo.. about 40 pounds front and back. I will post a picture tomorrow ( Night in OZ now ) if you are interested.. https://www.aliexpress.com/item/1005003565...0269100_15 2007 TDV8 VSE
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
For something a little more subtle, this is the ambient lighting I fitted to my FF, which matches in hue and colour with the 2020-> RRs (i eventually found the matching RGB to set through the app). https://www.fullfatrr.com/forum/post624201.html#624201 They only come on when the headlights are on (and don't flash when you flash main beam, as they're connected to the tail light fuse). 2015 Range Rover Autobiography 4.4 SDV8 |
