Home > Maintenance & Mods (L322) > ATF: Shell M1375.4 for 8-speed ZF box??
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
HI All,
So I’m a bit confused. The Owners Handbook I have states Shell ATF M1375.4 as ‘Main Gearbox Oil” but on researching this all I find is that this is for 6-speed auto’s, and I have the 8-speed! I had been looking to buy this https://www.ebay.co.uk/itm/303956199778?ha...3126959498 assuming it was correct as per 8-speed box but now having decided to check with the Handbook I’m lost - could I have a wrong/replacement Handbook? Can anyone advise? Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #637796 25th Jul 2022 10:57am
Mikey
Shell L12108 (ZF Lifeguard 8 )
Post #637800 25th Jul 2022 11:43am
kevinp
I contacted Smith and Allan and they confirmed that the one you have looked at on Ebay is the correct oil and it will mix ok with the ZF oil that will remain in the system. Hope this helps.
Post #637802 25th Jul 2022 11:59am
grayst01
thanks for that Kevin!
I did also end up contacting them too and when they used my reg to confirm details it came back as the 6-speed ATF version?? They recommended I contact LR direct for confirmation… all seems a bit more confusing than it should be Censored Will do that tomorrow Cheers, Steven.
Post #637819 25th Jul 2022 4:42pm
kevinp
Seems weird. Hope Smith and Allan didn't agree with the recommendation from your car details?
Post #637825 25th Jul 2022 5:44pm
grayst01
Hi Kevin
Not so much that they agreed, but that their systems did show it as requiring M1375.4 ATF but did state that that was unusual given the 8-speed box. I’ll contact LR todays for their verification. Cheers, Steven.
Post #637865 26th Jul 2022 7:22am
grayst01
Well… early call to local LR dealership (Taggarts) advised the correct spec as per reg & VIN for the car is M1375.4, even though it is an 8-speed box? I’m now even more confused… Feel as though I should obviously go with the spec advised and noted in the Handbbok too.
Could someone else with a circa 2012 4.4 TDV8 verify what their Handbook specifies regards ATF?? Big Cry Cheers, Steven.
Post #637867 26th Jul 2022 7:42am
JayGee
The workshop manual;
8spd - Shell L12108 Lifeguard 8
6 spd - M1375.4 2012 TDV8 Vogue (L322)
Post #637869 26th Jul 2022 8:04am
garyRR
AG60 is also an appropriate ATF.
Although, when I last looked (last week), buying the genuine ZF Lifeguard 8 oil and sump as a kit was about the same price as buying a different brand.
If you search ebay for 8HP70 kit, there's quite a few on there. 2015 Range Rover Autobiography 4.4 SDV8
Post #637870 26th Jul 2022 8:05am
kevinp
Hi Steven. Just checked my handbook and it says the same as yours.
If it helps, I had my oil changed at an official ZF gearbox approved garage and it had ZF lifeguard 8 put in. There is an obvious info mistake somewhere here mate. Ring a ZF approved garage up and ask them what grade they would put in if you need more reassurance.
Post #637871 26th Jul 2022 8:13am
JayGee
My MY12 handbook also specifies the M1375.4 but also lists both gearboxes so I'd suspect it's an error /omission. 2012 TDV8 Vogue (L322)
Post #637872 26th Jul 2022 8:17am
grayst01
Thanks All!
I’m going to speak to the local independent LR guys here, and explain the situation and see what they say… doesn’t help that LR themselves stated the M1375.4! Will update hopefully tomorrow… Thumbs Up Cheers, Steven.
Post #637956 27th Jul 2022 6:00pm
garyRR
Not sure what there is to ask?
You want Lifeguard 8 Automatic Transmission Fluid.
You've got a wide choice of:
Shell
Genuine ZF Lifeguard 8 (it is a ZF transmission, not Land Rover)
Smith & Allen (as you've already linked)
Mannol AG60
If you check the data sheets for any oil, they list the specifications they conform to. If in doubt, look at what the gearbox manufacturer specify for their gearbox (ZF Lifeguard 8 ). 2015 Range Rover Autobiography 4.4 SDV8
Post #637975 27th Jul 2022 8:20pm
kevinp
But that's the confusion, we know it needs lifeguard 8 and the handbook is saying Shell 1375.4 which is Lifeguard 6.
Post #637977 27th Jul 2022 8:27pm
garyRR
I'm not sure where the confusion is. 'Lifeguard 8' is what is needed. 2015 Range Rover Autobiography 4.4 SDV8
Post #637981 27th Jul 2022 8:47pm
