![]() | Home > Maintenance & Mods (L322) > ATF: Shell M1375.4 for 8-speed ZF box?? |
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 104 ![]() ![]() ![]() |
HI All,
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1786 ![]() ![]() |
Shell L12108 (ZF Lifeguard 8 ) |
thanks for that Kevin!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1272 ![]() ![]() ![]() |
Seems weird. Hope Smith and Allan didn't agree with the recommendation from your car details? |
Hi Kevin
Well… early call to local LR dealership (Taggarts) advised the correct spec as per reg & VIN for the car is M1375.4, even though it is an 8-speed box? I’m now even more confused… Feel as though I should obviously go with the spec advised and noted in the Handbbok too.
The workshop manual;
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
AG60 is also an appropriate ATF.
Hi Steven. Just checked my handbook and it says the same as yours.
My MY12 handbook also specifies the M1375.4 but also lists both gearboxes so I'd suspect it's an error /omission. 2012 TDV8 Vogue (L322) |
Thanks All!
Not sure what there is to ask?
But that's the confusion, we know it needs lifeguard 8 and the handbook is saying Shell 1375.4 which is Lifeguard 6. |
I'm not sure where the confusion is. 'Lifeguard 8' is what is needed. 2015 Range Rover Autobiography 4.4 SDV8 |
