Home > Maintenance & Mods (L322) > ATF: Shell M1375.4 for 8-speed ZF box??
kevinp
The handbook says Shell 1375.4 which is Lifeguard 6 !!!
Post #637993 27th Jul 2022 10:36pm
Phoenix
The handbook is wrong. As previously mentioned.
Lifeguard 6 will be 'OK', Lifeguard 8 will be the oil the transmission manufacturers intend to be used.
Post #637995 27th Jul 2022 10:39pm
garyRR
The gearbox manufacturer is ZF. ZF publish hoards of information about their transmissions, including suitable oil specifications. 2015 Range Rover Autobiography 4.4 SDV8
Post #637997 27th Jul 2022 10:42pm
kevinp
Lifeguard 8 has an extra additives package than the 6 so it is not 'OK'!
Post #638002 27th Jul 2022 10:58pm
Phoenix
It's 'OK' in that it's transmission oil designed for ZF transmissions, clearly it's not the right one (and I don't understand why you're arguing with yourself over this) but 'will do' in the absence of the correct ZF specified one. In the same way that 'some' engine oil is better than none at all.
Post #638004 27th Jul 2022 11:07pm
kevinp
If it's clearly not the right one why do you think it's ok to use. Foolhardy advice.
Post #638016 28th Jul 2022 12:22am
RRPhil
Does the Owners Handbook for your 2012 L322 cover the 5.0 V8 as well as the 4.4 TDV8? The petrol model uses the ZF 6HP28X transmission (which uses ZF Lifeguard Fluid 6, formerly Shell ATF M-1375.4) and the diesel model uses the ZF 8HP70X transmission (which uses ZF Lifeguard Fluid 8, formerly Shell ATF L12108). Could this be where the confusion has arisen, or is your Handbook specific to the 4.4 TDV8?
Phil
Post #638019 28th Jul 2022 12:57am
Mikey
garyRR wrote:
I'm not sure where the confusion is. 'Lifeguard 8' is what is needed.
This. I don't see the confusion
6HP box needs LG6, or equivalent
8HP box needs LG8, or equivalent
8HP oil is backwards compatible, and can be used in the 6HP box
No oils are forwards compatible
Post #638083 28th Jul 2022 5:23pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
Chaps
Wasn’t expecting this to be polarising… I thought it’d simply be 8-speed box so LG8, no questions. Until Smith & Allan informed me differently, and then on checking with LR they advise the same. I’m only a sh*t driveway enthusiast and have no authority to say anything but its very difficult to go against Dealer and oil specialists… Big Cry Big Cry
The attached pic is their last feedback to me…
I understand all the knowledge out here (after all its why I joined the forum) but I’m between a rock and hard place in deciding what to do. I don’t want to dismiss anyone’s experience or information. Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #638106 28th Jul 2022 8:45pm
Mikey
LG8 is a higher grade of oil than LG6.
I certainly wouldn't be using non LG8 approved oil in an 8 speed box. Spend a little extra, and get the right oil Thumbs Up
Post #638116 28th Jul 2022 9:52pm
grayst01
Hoping to!
I’ve contacted ZF Services UK Ltd, hope to get some finality with them. Censored Cheers, Steven.
Post #638118 28th Jul 2022 9:59pm
garyRR
I really don't understand why an ugly mountain is being made out of this.
The ZF 8HP70 uses Lifeguard 8 ATF. Either buy genuine ZF Lifeguard 8 ATF if you're that concerned or an ATF which conforms to the Lifeguard 8 standard S671 090 312 (for example Mannol AG60 which even has the standard printed on the front of the bottle and the actual Land Rover part number stamped on the back [LR023288]).
It's that simple and seems overkill to be contacting ZF to ask, when all of this information is freely available. 2015 Range Rover Autobiography 4.4 SDV8
Post #638125 29th Jul 2022 12:40am
DrRob
I'd be taking it to Mikey (first reply to your post on page 1) at MMP in Dundee for a Megaflush and let him sort it. He's a guru Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638140 29th Jul 2022 8:15am
grayst01
I had my reply back from ZF UK this morning.
After confirming vehicle reg and VIN they have recommended Lifeguard 8 ATF (or equivalent). I had explained the mixed message from LandRover and handbook etc.
So big thanks to all for the feedback Bow down I know it seems like a big of a ‘well, duh!…’ as far as using LG8 but when you’re a DIY’er and your local dealership and handbook tell you one thing its hard to then decide for yourself to go against that! Can only imagine the people maybe in my position that have followed incorrect handbook guidance…
Thumbs Up Cheers, Steven.
Post #638171 29th Jul 2022 12:32pm
DrRob
8 speed has a thermostatic valve in line with the oil cooler I believe so different flush protocol to the 6speed.
Hence I had Bodsy do it on my drive with his mobile Megaflush as part of my preventative maintenance program Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638182 29th Jul 2022 1:24pm
