when you lift the upper part of the tail gate and look up to the metal area at the top you will see three 10mm bolt heads, left, right and centre.
undo these, they are quite short. pull the spoiler rearwards, it will be quite stiff. it is held in place on two rubber bungs and they engage in key slots on the spoiler, so fitting is easy and will get you back in near enough the same place. i used a fine marker pen and drew around the washers so i got things exactly back where they came from.
the only thing to be carful of is the spoiler has wires in it for the brake light and they are quite short in length. i put an old sheet on the roof and when the spoiler was removed, laid it on the roof at such and angle as to not pull the wires.
the interior trim only needs to be removed if you neeg to get access to the motor. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
