Home > My Range Rover > Help ... f***ed up!
Chrali
Help ... f***ed up!
Well I thought I'd replace my lower arms and drop links like everyone else does with no too much agro.
It was tragic.
Applied WD40 over the last week.
Had to use a hammer to force the socket on to get a couple of the wheel nuts off.
Jacked up with my new 3 tonne Sealy jack and axle stands.
Wheel off.
Start with the top drop link which unbolted easy, bottom bolt didn't.
Deployed my size 9s and it shifted BUT the Censored thing is just spinning.
Broke the sealed side to see if there was anyway I could apply leverage.
Didn't see any Big Cry ready to quit.
Tried to lift the jack so I can get the wheel on, but the jack expired in a puddle of its own oil and it was caught on the jacking point so wouldn't come down. Double Censored
Luckily had space to use the the cars own scissor jack to lift and got the wheel back on.
I was also sweating buckets in the 28 degree heat.
Any ideas before I Bow down to my local garage?
 Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #636715 12th Jul 2022 1:49pm
Phoenix
Hacksaw through the nut to remove the outer bit where its binding, leave enough of the hex to get a spanner on though, then put an axle stand under the drop link so as to bind the threaded bit in the hole through the anti-roll bar.
Post #636717 12th Jul 2022 1:56pm
Pysta
Slovakia 2011 Range Rover Vogue TDV8 Fuji White
Re: Help ... f***ed up!
*most* have the possibility to put a wrench on them (14-18mm mostly) to avoid this issue
Post #636721 12th Jul 2022 2:30pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Just one of those simple jobs that turns to Rat S***. Shocked
As Pysta, has mentioned, see if you can get a thin spanner in by the rubber seal. As you've been soaking it in WD 40, it sould come undone.
Post #636723 12th Jul 2022 2:55pm
Chrali
Indeed Laughing Thanks for the advice, yes I'll see if I can get a spanner on it, I forgot that! It it requires more than that, it can go into the garage as I need the car this week. That's the downside of it being our only car. Encourage alternative fuels, use all the petrol!
Post #636724 12th Jul 2022 2:59pm
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
I ended up putting a reciprocating saw through the threaded part. After hours trying to free it wish i had done that to start with.
Post #636725 12th Jul 2022 3:00pm
Chrali
Cheers guys,
I didn't see it originally, but I was able to get a 18mm spanner on it and remove the nut. To me it wasn't obvious as its not a bolt as such, more a couple of barely noticeable flat edges.
Ok next problem. How do I get the drop link off, as the threaded bolts are at an angle? I tried using the jack to lift at various points but didn't see any improvement. I'm just concerned if I knock it out, I'll not get the new one on.
If this is the easy bit, god help me Shocked
Sorry for the novice problems, I don't normally do this kinda of work on my L322. Encourage alternative fuels, use all the petrol!
Post #636733 12th Jul 2022 3:44pm
Pysta
You'd need to have both wheels off the ground to not have a ton of pressure on the link .. then it just needs a prybar (which you'll need to insert a new one too) and a whack.
Post #636734 12th Jul 2022 3:47pm
Chrali
Ah ok, I've got a wheel on the ground. How much of a pry bar do I need? All I have is my breaker bar, that sounds a bit small. I'll jack up the other side and see if that improves things. Encourage alternative fuels, use all the petrol!
Post #636735 12th Jul 2022 3:51pm
Pysta
With both wheels off the ground it's 1-2cm you need to take care of, for which a breaker bar is ok
Post #636736 12th Jul 2022 3:58pm
dingg1
I managed ok with the opposite wheel still on the ground just using a length of wood to persuade the antiroll bar to be in the correct position
Good luck
Ps I handed the control arms that have the removable ball joint located in the knuckle to a garage and he had a bit of a job with them, they can be somewhat problematic Laughing
Post #636737 12th Jul 2022 3:58pm
Highroller
"they can be somewhat problematic " Dinng1 - That's a bit of an understatement Rolling with laughter
I would say that they can be an absolute Censored - Mine didn't want to come off with two ball joint spliters, in the end I beat the Censored out of it before it moved. The bolt & nut removal were easy though Very Happy
Post #636738 12th Jul 2022 4:23pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
[quote="dingg1"]I managed ok with the opposite wheel still on the ground just using a length of wood to persuade the antiroll bar to be in the correct position
+1 Thumbs Up from me - I recently replaced both fronts drop links with the opposite wheel still on the ground! Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #636743 12th Jul 2022 5:23pm
Chrali
Lifting the other wheel helped me enormously, although I still had to use my jack handle to lever the bolt threads fully through. The other wheel also had swollen nuts Laughing and took some weird and wonderful prying and levering to get the drop link nuts off.
The drop link om that other wheel slid straight into position without any effort. Here's the first one I did. Thanks for your help guys, as I was going to quit. Not sure when I'll try the lower arms now, as I'm broken and sweaty enough for now, especially using a scissor jack in 28 degrees heat! Thud
Should the drop link nuts be tightened on the ground?
Also the old links had a washer on the upper nut, that the new Delphi parts didn't, so I didn't reuse it. Is that ok?
Post #636748 12th Jul 2022 5:47pm
Pysta
Yes it absolutely can be done with the other wheel on the ground, but it's waaaay easier with both of them jacked up.
When you replace the swollen nuts, make sure to clean up the threads as they might (will) mess the new nuts up too.
They can be tightened as is
Post #636752 12th Jul 2022 6:00pm
