Home > Technical (L405) > Multiple warnings! SOLVED
Page 2 of 3 <123>
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Merchy wrote:
Apparently there is an earthing point near the fuse box in passenger footwell.
The below is the only other thing I have found relating to L405 earths, I do not know if this applies to your car.
https://www.google.com/url?esrc=s&q=&a...ehptmmBqXm
Hopefully someone should be able to point you in the right direction soon
Thanks again Merchy
Post #635976 3rd Jul 2022 12:32pm
Brerfox
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
just a thought have you checked to see if all your belts are intact and tight?
Post #636013 4th Jul 2022 1:02am
kgeddes
Just back from holiday and scanned ECUS with IID Tool, here’s the results. Some of the faults have cleared but still 16 present! Anybody see any clues amongst all this! Thanks in advance….
L405 - Range Rover 2013
Vehicle scanned on 09-07-2022 12:22
Using IIDTool BT V4.0 B2691
ACM-Audio System
U2005-62 (2C) Vehicle speed - Algorithm based failure - signal compare failure
ATCM-Terrain Response
U0121-00 (2F) Lost communication with ABS control module
( on 09-07-2022 12:18:04 at 182959 km )
U3003-62 (2F) Battery voltage - Algorithm based failure - signal compare failure
BCM-Body Control
B123B-15 (6C) Front right turn signal - General electrical failure - circuit short to battery or open
( on 02-07-2022 10:40:42 at 182959 km )
( on 02-07-2022 10:31:31 at 182959 km )
B1C99-15 (6C) Right corner lamp circuit - General electrical failure - circuit short to battery or open
CCM-Cruise Control
U0121-00 (AF) Lost communication with ABS control module
U3003-16 (2E) Battery voltage - General electrical failure - circuit voltage below threshold
( on 09-07-2022 12:18:19 at 182959 km )
CHCMB-Chassis Control
U300A-64 (2C) Ignition switch - Algorithm based failure - signal plausibility failure
( on 02-07-2022 10:32:52 at 182959 km )
U300A-62 (2C) Ignition switch - Algorithm based failure - signal compare failure
U0100-00 (2C) Lost communication with engine control module/powertrain control module 'A'
( on 02-07-2022 10:33:02 at 182959 km )
U0101-00 (2C) Lost communication with transmission control module
CHCM-Chassis Control
HCM-Headlamp
B1D65-87 (AF) Motor operation malfunction of right actuator - Bus signal/message failure - missing a message
( on 02-07-2022 10:31:35 at 182959 km )
( on 02-07-2022 10:31:34 at 182959 km )
HVAC-Ventilation
B105A-97 (2Cool Cabin temperature sensor fan - Component failure - component or system operation obstructed or blocked
( on 24-06-2022 11:24:06 at 182819 km )
B12B9-16 (2C) Auxiliary heater control module - General electrical failure - circuit voltage below threshold
( on 03-07-2022 14:05:17 at 182959 km )
IPC-Instrument Pack
( on 02-07-2022 10:34:23 at 182959 km )
IPMB-Camera
B12C0-19 (2F) Left mirror camera - General electrical failure - circuit current above threshold
( on 24-06-2022 12:14:07 at 182819 km )
B12C0-31 (6Cool Left mirror camera - Frequency modulation/pulse width modulation failure - no signal
( on 26-06-2022 15:19:00 at 182908 km )
B12C0-49 (2Cool Left mirror camera - System internal failure - internal electronic failure
( on 24-06-2022 11:24:01 at 182819 km )
U201A-51 (2Cool Control module main calibration data - System programming failure - not programmed
( on 11-11-2026 09:41:58 at 0 km )
PAM-Parking Aid
U0121-87 (6C) Lost communication with ABS control module - Bus signal/message failure - missing a message
( on 02-07-2022 10:39:27 at 182959 km )
U0415-86 (6C) Invalid data received from ABS control module - Bus signal/message failure - signal is invalid
PBM-Parking Brake
( on 02-07-2022 12:49:37 at 182959 km )
U3006-16 (2C) Control module input power A - General electrical failure - circuit voltage below threshold
( on 03-07-2022 14:38:00 at 182959 km )
PCM-Engine TDV8
U0416-68 (2F) Invalid data received from vehicle dynamics control module - Algorithm based failure - event information
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
( on 24-06-2022 11:24:02 at 182819 km )
U0415-68 (2F) Invalid data received from ABS control module - Algorithm based failure - event information
P0700-00 (2F) Transmission control system (malfunction indicator lamp request)
( on 02-07-2022 10:33:05 at 182959 km )
PSCM-Power Steering
B1304-16 (2E) Electronic power assisted steering system - General electrical failure - circuit voltage below threshold
U0121-31 (2F) Lost communication with ABS control module - Frequency modulation/pulse width modulation failure - no signal
U3001-00 (2F) Control module improper shutdown
RCM-Airbag
U0121-00 (2B) Lost communication with ABS control module
SODL-Left Side Object
( on 02-07-2022 10:31:33 at 182959 km )
U3003-62 (2Cool Battery voltage - Algorithm based failure - signal compare failure
( on 25-06-2022 08:41:33 at 182879 km )
SODR-Right Side Object
SPMA-RH Seatbelt Pretens
U0001-87 (2F) High speed CAN communication bus - Bus signal/message failure - missing a message
SPMB-LH Seatbelt Pretens
TCCM-Transfer Case
( on 09-07-2022 12:18:20 at 182959 km )
TCM-Transmission
U0121-63 (AF) Lost communication with ABS control module - Algorithm based failure - circuit/component protection time out
P279D-02 (2F) Four wheel drive range signal circuit - General failure information - general signal failure
TVM-Television
U3000-49 (2Cool Control module - System internal failure - internal electronic failure
Post #636464 9th Jul 2022 11:56am
kgeddes
Does anybody know if I can get into the boot area - the button and remote are not opening it. It has executive seating so climbing into the boot appears to be impossible! Big Cry Can the IID Tool open the tailgate? Thanks in advance…. Thumbs Up
Post #636470 9th Jul 2022 1:23pm
Merchy
I am assuming that you were on your hols when this all started -
Unless you have some serious wiring damage somewhere or water ingress, which seems unlikely, then all this still points to battery / earth wires and other wires to the battery / connections / alternator & connections etc.etc.
You would have to get further advice about a hard reset on an L405 from someone else with more knowledge than me, but could be a plan, and will cost nothing but a little time.
I would start with all that or go to a reputable Indy / auto electrical oufit, or similar and get them to test the battery / systems, because there are so many completely unrelated faults that there must be a common cause for all these faults.
Just to indicate these types of problems, read the current thread 'Car just died, any ideas?' initially it seemed to be
a horrendous problem and turned out to be a battery cable problem, that affected everything.
Just had a thought, in addition to my above waffle, as you have not reported any other faults with the car, are most of these systems actually working ? If so then the above is most likely to be your problem. Hope this helps.
Post #636471 9th Jul 2022 1:27pm
kgeddes
Thanks again Merchy, fault code U0121-00 (abs module) appears in a lot of the list of faults. The biggest issue I have at the moment is getting into the boot area as it’s electric and won’t open, made worse as I can’t climb in (see above post)…I’m hoping the IID Tool can open it!
Post #636477 9th Jul 2022 1:51pm
Mikey
Have you checked the earth's in the front arch, as previously advised?
Post #636484 9th Jul 2022 3:27pm
Merchy
Mikey's idea would be a good place to start - also if you want to charge the battery from under the bonnet, check the below thread, including pics. As before on the screen on the L322 you can get the battery charging voltage on the display, I would think this SHOULD be possible on yours, but don't take this as gospel.
https://www.fullfatrr.com/forum/topic58249.html
Post #636485 9th Jul 2022 3:33pm
kgeddes
Hi Mikey, I’m just back from holiday today and ordered an IID Tool whiltst I was away. I haven’t checked the earthing points as the supplying garage has told me this afternoon to take it to a main dealer to have it repaired, at their expense…..many thanks for your guidance and I’ll let the forum know the outcome…..the unlocking tailgate is a mystery in all this. Thanks again Thumbs Up
Ps. I intend to come to you guys for my 120 month service…my mother lives in Crail, Fife so you’re not too far away Thumbs Up
Post #636490 9th Jul 2022 4:23pm
Merchy
See the thread -
https://www.fullfatrr.com/forum/topic62384.html
As Mikey suggested, this could well be the problem, at least point the dealer in that direction, as some main dealer staff are not the best at fault diagnosis. Not all, but seems to be pot luck from comments on here.
At least you will not be paying for the work. Thumbs Up
Post #636521 9th Jul 2022 8:48pm
kgeddes
Thanks again Merchy, I’ve just read that thread - pretty much identical IID Tool fault list I have (with the exception of the tailgate which won’t open)…I’m sure the earth connection/s will be the cause. I’ll give the dealer the IID faults list and Mikey’s suggestion. Next thing is to arrange for a recovery truck to take it there on Monday - 160 mile round trip! Crying or Very sad
Post #636526 9th Jul 2022 9:19pm
kgeddes
Well, it got worse (flat battery) then it got better (after jump start the tailgate came back to life). I think I’m going to have a look at the earth connection in the o/s/f wing tomorrow.
Mikey, is if correct to say that it’s just the front part of the underwing that has to be removed (5 or 6 screws)?
Thank you Thumbs Up
Post #636613 10th Jul 2022 9:11pm
Mikey
Correct, just the front part Thumbs Up
Post #636631 11th Jul 2022 4:46am
kgeddes
Well done Mikey! Exactly as you diagnosed - earth connection under o/s front wing…..well done! Bow down
I ended up having it recovered to dealer by the AA as warranty is covering costs…..£350 + vat😮
Definitely worth checking this as it cripples the 405!
Thanks again Mikey! Thumbs Up
Post #636863 14th Jul 2022 9:27am
Mikey
Quite common, you see
Easy to diagnose, easy to repair Thumbs Up
Post #636888 14th Jul 2022 6:12pm
Page 2 of 3 <123>
