Home > Technical (L322) > Resonance/groan when accelerating 2012 4.4 TDV8
FujiRR
United States 2011 Range Rover HSE 5.0 V8 Fuji White
I have a similar issue on my new to me 2011 5.0 n/a Its annoying but I also can't seem to make it happen it has a mind of its own and it starts and stops suddenly very intermittent. Almost as if its a fan or blower cutting in and out. But with enough vibration you can feel and hear it.
Post #636151 6th Jul 2022 9:23am
Umiar
Poland 2011 Range Rover Vogue TDV8 Zambezi Silver
kevinp wrote:
Can you guys replicate the noise revving the engine with the car stationary?
No strange noise when stationary. Maybe 10% of it but ta much higher revs, 2500-3000…
Post #636255 7th Jul 2022 5:34pm
JayGee
In addition to a new AC compressor I had the fuel filter and brake fluid changed and the gearbox oil topped up ( small leak requiring further investigation) - can't hear the sound now. 2012 TDV8 Vogue (L322)
Post #637539 22nd Jul 2022 8:31am
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Mine makes the "blowing across the top of a bottle noise" when air recirc is on.
I had assumed perhaps a blend door not closing properly.
Most noticeable at 50mph and above.
Volume increases with speed. 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #637779 24th Jul 2022 11:35pm
KristoffL322
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Finally got an update on this. I've fixed the noise!
I'm investigating an oil leak so thought I'd have a proper look to see if I could find anything amiss whilst I was down there.
Takes me an hour to jack the car up as I'm so paranoid about being pancaked that I use three jacks and 4 axel stands.
Anyway, I can't have looked too hard last time as there was clearly a snapped bolt in the bellhousing/gearbox (not sure what you call it) metal shield thing.
Looks like a previous spanner monkey had snapped it off and not bothered fixing it. I centre punched it and drilled it first with a cobalt bit, then stepped up one size with a left hand drill bit and it came out with no real drama and without damaging the threads. I made a replacement by grinding a bolt to a taper on the bench grinder and that was that. No more noise.
Still haven't a clue about the oil leak, investigations continue on that front. But that noise was seriously annoying, so I'm glad its gone.
Hardly a candidate for 'repair of the year' but I hate it when threads are not resolved, so I thought I'd post the solution to my problem.
 2012 4.4 TDV8 Westminster
Post #658547 5th Mar 2023 5:59pm
JayGee
Despite my earlier post saying the noise had gone I can confirm it didn't go. I noticed the other day when starting on a slope with the window down that the sound was accompanied by a metallic rattle / resonance so this may well be the cause on mine as well. 2012 TDV8 Vogue (L322)
Post #658550 5th Mar 2023 6:09pm
DrRob
Sort that oil leak. I’ll bet it’s the oil cooler in the V up top. Replace the cooler, gaskets and the 2 O rings. Loads of detail on here about it in Wiki. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658556 5th Mar 2023 6:43pm
KristoffL322
Yes I suspect it is the oil cooler. I've ordered the gaskets and the viton o rings and will get it done when they arrive. The reason for getting the underside stripped down was to check that it wasn't the turbo return pipes, and they look ok, so oil cooler seems likely.
I suspect it had this fault when I bought the car last May. I pointed out a slight oil leak when it went back for new rear shocks under warranty from the dealer, the dealer said it wasn't the oil cooler, just excess drips from the oil change. There was no evidence of oil in coolant or coolant in oil, so not really much I could do. There is still no evidence of either. It's taken until now for any oil to reappear. So I pretty much knew this was coming. 2012 4.4 TDV8 Westminster
Post #658602 6th Mar 2023 10:36am
DrRob
They were covering that up I have no doubt! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658607 6th Mar 2023 11:10am
JayGee
Just been under mine and the gearbox shield does rattle like a biscuit tin lid. I took it off but couldn't see anything wrong or where it was touching so put it back again and it seems to be silent now. Been driving around this afternoon with the window down and the familiar moan at very low revs is totally gone Thumbs Up 2012 TDV8 Vogue (L322)
Post #663609 7th May 2023 4:27pm
CharlieF322
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Hell, did you get anywhere with the fuel pump after the fuel filter change comment? This is exactly what mine is doing after a fuel filter change. I’m assuming there is no air in the system as it starts and drives without mishap.
Just an annoying sound that wasn’t there before Sad
2012 Westminster
4.4 TDV8
Baltic Blue
Post #689311 29th Mar 2024 12:14pm
Anglo77
United States 2011 Range Rover HSE 5.0 V8 Stornoway Grey
Had this appear on my 2011 as well. Last thing I had done was a gearbox oil and filter change so suspected I had introduced it. I have checked the oil level several times, as in my head the sound sounded like a suction sound to me, but went away at high revs too. Maybe oil pressure related?
Checked all the heat shields too, nothing out of place or loose.
Today I have found the high pressure fuel rail cross over pipe is vibrating. So I am suspecting that there is air in the system. But I have not touched anything in the fuel system.
Does anyone know if there is a bleeding procedure for the fuel system?
I found a de-pressurise procedure, pulling out the fuel pump fuse and letting the engine idle until it stalls. I can't find a fuel pump fuse in my 2011. Crying or Very sad 2011 L322 5.0L HSE & 2018 Discovery Sport 2.0L
Previous: 2003 Discovery 4.6 V8 SE / 1990 RR Classic 3.9 V8 Vogue / Series 2A 2.25 (X2 1965 & 1968)
Post #689384 29th Mar 2024 11:45pm
