Home > Maintenance & Mods (L322) > Tow bar frame and side steps transfer from 2004 to 2010
Flashman
I am looking to upgrade from my 2004 Td6 to a 2010/11 L322 and wondered if I could transfer the tow bar frame and fixed side steps (both OEM) from my old car to the new one if the replacement does not have them fitted already?
Would it just be a straight swap? Tom
Current Drive
Previous Drives
Post #634061 8th Jun 2022 5:21pm
mjdronfield
Should all move across, though I understand the exhaust hanger is in a different place on the tow bar frame, so you might need to fabricate that.
Still easier than finding another tow bar I recon….
And if you want the rear luggage net cassette… the new car might not have the side trims for it to clip in to.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #634067 8th Jun 2022 5:43pm
Flashman
Great to know, thanks for the info.
I retrofitted the luggage cassette on my old car and it had the roof clips already in place, not sure I am too bothered about having it in the new car, but will check just in case! Tom
Current Drive
Previous Drives
Post #634069 8th Jun 2022 5:49pm
mjdronfield
Not the roof clips, they will be there, it’s where the whole thing clips in on top of the plastic side trims near the rear side windows.
Took the cassette out my TD6…. Then the 2011 didn’t have the mounts 🤣.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #634076 8th Jun 2022 6:02pm
Flashman
Ah, yes the button release vented plastic side shoulder trims with the silver lines. Definitely worth keeping the old trims and cassette just in case. I remember the hassle of getting them from the main dealer back in 2012 so would probably be even worse now. Tom
Current Drive
Previous Drives
Post #634081 8th Jun 2022 6:44pm
garyRR
Re: Tow bar frame and side steps transfer from 2004 to 2010
All I'd say is it might be quicker and easier to buy a new tow bar. The steps shouldn't be so bad to remove (bear in mind there may be a hole drilled in the front panels for the mud flaps) but the big old bolts on the tow bar and rusted nuts on the exhaust hangers could make it a pig of a job to remove.
Fitting a tow bar to my car took me about 8/9 hours (dark winter months) so, I dread to think how long it would take to remove, fit exhaust hangers to the old car then re-fit with rusted old fittings to the new car - might just be easier to find a car with a tow bar or just buy a new tow bar. 2015 Range Rover Autobiography 4.4 SDV8
Post #634242 10th Jun 2022 8:58am
