![]() | Home > Maintenance & Mods (L322) > Tow bar frame and side steps transfer from 2004 to 2010 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Should all move across, though I understand the exhaust hanger is in a different place on the tow bar frame, so you might need to fabricate that.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Great to know, thanks for the info.
Not the roof clips, they will be there, it’s where the whole thing clips in on top of the plastic side trims near the rear side windows.
Ah, yes the button release vented plastic side shoulder trims with the silver lines. Definitely worth keeping the old trims and cassette just in case. I remember the hassle of getting them from the main dealer back in 2012 so would probably be even worse now. Tom
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
All I'd say is it might be quicker and easier to buy a new tow bar. The steps shouldn't be so bad to remove (bear in mind there may be a hole drilled in the front panels for the mud flaps) but the big old bolts on the tow bar and rusted nuts on the exhaust hangers could make it a pig of a job to remove. Fitting a tow bar to my car took me about 8/9 hours (dark winter months) so, I dread to think how long it would take to remove, fit exhaust hangers to the old car then re-fit with rusted old fittings to the new car - might just be easier to find a car with a tow bar or just buy a new tow bar. 2015 Range Rover Autobiography 4.4 SDV8 |
