Home > Maintenance & Mods (L322) > Tow bar frame and side steps transfer from 2004 to 2010 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Should all move across, though I understand the exhaust hanger is in a different place on the tow bar frame, so you might need to fabricate that.
8th Jun 2022 5:43pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Great to know, thanks for the info.
8th Jun 2022 5:49pm |
Not the roof clips, they will be there, it’s where the whole thing clips in on top of the plastic side trims near the rear side windows.
8th Jun 2022 6:02pm |
Ah, yes the button release vented plastic side shoulder trims with the silver lines. Definitely worth keeping the old trims and cassette just in case. I remember the hassle of getting them from the main dealer back in 2012 so would probably be even worse now. Tom
8th Jun 2022 6:44pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
All I'd say is it might be quicker and easier to buy a new tow bar. The steps shouldn't be so bad to remove (bear in mind there may be a hole drilled in the front panels for the mud flaps) but the big old bolts on the tow bar and rusted nuts on the exhaust hangers could make it a pig of a job to remove. Fitting a tow bar to my car took me about 8/9 hours (dark winter months) so, I dread to think how long it would take to remove, fit exhaust hangers to the old car then re-fit with rusted old fittings to the new car - might just be easier to find a car with a tow bar or just buy a new tow bar. 2015 Range Rover Autobiography 4.4 SDV8 |
10th Jun 2022 8:58am |
