Home > Maintenance & Mods (L322) > So here is what is lurking behind my sills and arch liner.
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Took the sills off and wheel arch liner on the 2006 S/C.
Was dreading it, and here is what I saw. (There is some damp as I was cleaning the area).
Post #633365 31st May 2022 4:05pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
wow - Best one I've seen Shocked
Post #633369 31st May 2022 4:27pm
philip1972
I am pleased to say the least. Still gave it a coat of stuff for precaution, thought I may as well while I was in there.
Thanks h and anyone who says the arch liner goes in easier than coming out is lying Smile
Post #633370 31st May 2022 4:30pm
dingg1
Has it had a sheltered life?
Looks great btw Thumbs Up
Post #633372 31st May 2022 4:46pm
JCW
Rear arch liners are a pig to refit - trick I found helped no end was to leave them in hot sun for a good while which makes them more flexible to wrestle back in.
Post #633373 31st May 2022 4:54pm
philip1972
Good tip on leaving in the sun.
The car lived in Jersey from new until I got it. I was a little worried about rust being an island and sea air, but maybe it spent its life in a garage?
Post #633374 31st May 2022 5:02pm
dingg1
No salted roads in Jersey Thumbs Up
Mine had its first 3 years in Majorca which should have helped a bit, plus the last 4 in Portugal, its not bad underneath but I'm reluctant to start looking under covers and sills Laughing
Post #633376 31st May 2022 5:26pm
redsportt
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
cold starts
a lot of cold starts and engine not heating up properly is the downside of small island cars
Post #633388 31st May 2022 7:14pm
philip1972
Tut is very true, but unlike my previous big Diesel engines, the petrol seems to get up to temp in about 2 miles!
Post #633397 31st May 2022 8:00pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
you want to make sure that the drain slots in the sill to body panel are nice and clear i use a old hacksaw blade and slide up and blow them out with a air line . and remove all gromits along sill and spray some lanoguard in to the cavity this is nice and thin stuff and will not block the drain outlets if water is getting in it has to come out its when outlets are blocked and then you get the rot problems use a thicker protector on the outside i have used epoxy resin all in around my wheel arches and outer sills this will stop any more surface rust returning time consuming but job well done at the end new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #633454 1st Jun 2022 11:18am
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
They really are in excellent condition Thumbs Up .. mine needed some attention Crying or Very sad -
 Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #633457 1st Jun 2022 11:38am
